586,075 active members*
3,871 visitors online*
    May 2007
    29
    Cold Rolled Steel Uk sourcing?
    Just trying draw some attention to one of the problems affecting my build and potentially many UK builders.
    I have been told and now know from a days worth of researching that 6mm thick cold rolled steel is not produced in the UK.
    3mm is the apparent standard.
    So I was think to just buy double what I need and just bolt them together maybe to achieve the 6mm.
    Has any one tried this out before?
    Cheers for input.
    Mar 2009
    624
    Quote Originally Posted by rbs View Post
    Cheers for input.
    Dont think this is correct and i think i know a man who has got some or did get some, i will enquire for you.
    There may be a possibilty that he would want to sell it.? . . . I will send you a pm explaining why.?
    Cheers
    Dean.
  1. Cold rolled steel, flats or square for use as rails.
    By Apples in forum Linear and Rotary Motion
    Last Post: 06-26-2012, 03:51 PM
  2. All metal Z-axis design useing skate bearings and cold rolled steel
    By FandZ in forum DIY CNC Router Table Machines
    Last Post: 07-25-2009, 02:24 AM
  3. cutting oil for 1/4" cold rolled steel?
    By groomden in forum DIY CNC Router Table Machines
    Last Post: 03-19-2009, 05:50 AM
  4. Cold Rolled Steel Accuracy
    By Zach_G in forum Mechanical Calculations/Engineering Design
    Last Post: 11-26-2008, 03:59 AM
  5. Need to cut 1 x 4 cold rolled steel - Product Review
    By jderou in forum Uncategorised MetalWorking Machines
    Last Post: 07-06-2005, 05:24 PM
