586,103 active members*
3,776 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Parameter settings for memory
    Jul 2008
    45
    Does anyone know the parameters to change on a i series Fanuc controller to double the memory? Is it 0901? The machine is a Daewoo DMV-3016d.
    Aug 2010
    156
    what i series is it? 15 16 30 31 and most likly if it is 16 30 31 you can not do it. within the last 4 years Fanuc has developed a way to keep us all from changing option parameters. the have a logarithm generator that takes todays date and the machine serial number and generates a new password that is only good for 2 days and only on that particular machine. this password along with the option parameter is then E-maild to the closest Fanuc office and brought to your machine on a memory card. the card is inserted to the machine a new screen that has a load option key is pressed and the option loaded. if you try and change an option parameter your control will lock up and Fanuc will have to come in anyway and you be paying twice.
    Jul 2008
    45
    Thanks for the reply.
    I have already given up on the idea of trying to do this. It is not that big a deal for us anyway.
    I do have another problem. We have a 4020d and the machine will not run with the door open. You must close the door completely, and then, when it stops, you have to hit a door request button before it allows you to open it. Is there a way to bypass this? The controller is a 21i MB
  1. 0TC parameter for more memory?
    By jani in forum Fanuc
    Last Post: 01-16-2010, 11:44 PM
  2. Haas Parameter Settings?
    By Zak@CWS in forum Haas Mills
    Last Post: 06-11-2009, 09:29 PM
  3. Parameter Settings for Toyoda Lathe (FANUC 11T)
    By obieron in forum CNC Machining Centers
    Last Post: 02-05-2009, 04:23 PM
  4. Memory Parameter Error?
    By John3 in forum Fanuc
    Last Post: 09-07-2007, 03:17 PM
  5. Safe parameter settings for 730 and 731
    By 1ctoolfool in forum Haas Mills
    Last Post: 06-16-2007, 09:14 PM
