Cooling
Ok, this sounds like someone doesn't want to use coolant which is a proven way to do what is needed.
So is your machine in a basement or a ultra clean garage where coolant would make a mess?
I use coolant, it can be messy, it's in my shop, it gets messy, I manufacture stuff, it's in a shop. Coolant works.
I would think that using air would take quite a good compressor to keep up if you are doing any length of cut time.
RAD. Yes those are my initials. Idea, design, build, use. It never ends.
PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
