586,075 active members*
3,982 visitors online*
Results 1 to 17 of 17
    Nov 2004
    65
    Wink turbine model
    here's a link to a model turbine , with drawings in Autocad & Catia
    time to gcode it probably !
    the site is in german , however it is easily followed to the specs and the download files section
    anyone more knowledgeable
    http://www.htl-steyr.ac.at/htlde/am/...rb2/index.html
    Mar 2004
    1306
    Thanks for the link. We sure didn't do anything this cool when I was at school.
    Regards,
    Mark
    Aug 2005
    7
    I can't find it. Don't know if they have updated the website or what.
    Could you email them to me?
    [email protected]
    Nov 2004
    65
    i have just emailed the autocad files to you
    regards
    Dave
    Sep 2005
    1660
    Dave, do you think you could just post them up here as an attachment. I've looked at the site and I've not been able to locate them. I'm sure others are curious as well..
    Thanks!
    Jerry
    JerryFlyGuy
    The more I know... the more I realize I don't
    Jan 2007
    148
    here you go , these are for autocad , i have them for catia also however they are a large zip , so email or pm me if you require them .
    i would appriciate any changes or amendments anyone implements
    and i'll update the archive's for future use .
    Dave
    Jan 2007
    148
    ok noticed the upload failed as it's over the allowed file size
    Apr 2005
    281
    Dave,
    If it is no trouble I would like the files also. I am building the kj and it would be nice to compare as there are all sorts of mods now out. I am starting over as I now have a mill/drill along with my lathe. Just completed a couple of shafts.
    My email address is on here somewhere. [email protected]
    Thanks in advance,
    John
    Jan 2006
    357
    I would like the files also [email protected] dot com
    Thank you in advance!!
    Jan 2007
    148
    OK everyone , they are on their way
    all i ask is if you make changes or additions let me have them
    and i'll keep a up date for everyone on the list
    hopfully in time , we may get a complete cnc build with the g code files etc , / simulation for everyone .
    Dave
    Jan 2007
    148
    Quote Originally Posted by vulcom1 View Post
    Dave,
    Thanks in advance,
    John
    yes i have built the KJ , use the 2039 compressor wheel , you will find a better thrust ratio , it's a little more expensive but worth it
    the Schwitzer ( borg warner) part number is 53261232039
    are you a member of the GTBA ?
    http://www.gtba.co.uk
    Dave
    Apr 2005
    281
    Dave,
    Thought I would mention it here that I got your files. ((Much appreciatted))
    I was a member of the GTBA but due to the changing around and going pay pal I never got it renewed. Herb used to offer it on this side of the pond but that changed also. I offered to take memberships for them but no return answer so I dropped it. It is still a good idea to belong and maybe will get back.
    I have (2) 2038's that I purchased from Dieter in Switzerland and a 66mm turbine from Sarah at Wren. I am building a twin (CF100) 1/5th scale as a long going project.
    Thanks, John
    Jan 2007
    148
    Dave,
    Thanks, John
    well i can only reply from my own experiences , and the answers yes .
    the amount of help from experienced people who know is invaluable , i just could not have jumped over the hurdles and the gotcha's so quick without the help of the members .
    the GTBA are now fully web based , and only accept paypal , so it's a lot quicker to become a member ,
    all i can say is between CNCzone & the GTBA i have learned 100 times faster , and possibly safer too !
    only downside is the mounting heap of started projects that need to be finished after seeing other peoples works , and the wish list becomes larger !
    Dave
    Dave
    Jul 2006
    1062
    Jan 2006
    4396
    Here is a Turbine done by Tjones in Alibre Design Professional. Edited in BCC and had a friend changed the color with SolidWorks
    Have Fun!!!!!!!:rainfro:
    Attached Files Attached Files
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Aug 2005
    276
    Just a quick question... CAn you use a turbine to generate a large Vacuum??
    with a high FLOW rate ??
    Jan 2006
    4396
    Quote Originally Posted by Salty72 View Post
    I think so. Maybe Geof is the one you should ask. Send him a PM.
    Toby D.
    Schwarzwald
  1. Taking Delivery on Techno-Isel 4'x4' 130 Model
    By mtuckf in forum Commercial CNC Wood Routers
    Last Post: 03-23-2005, 03:20 PM
  2. 1/5 scale Model A engine
    By woodythx13 in forum I.C. Engines
    Last Post: 12-17-2004, 09:16 PM
  3. RFQ closed - scale model machined auto wheels needed
    By joemartins in forum Employment Opportunity
    Last Post: 10-27-2004, 02:16 PM
  4. Solid model to CNC code quession
    By mikenelson in forum Uncategorised CAM Discussion
    Last Post: 07-08-2003, 03:55 AM
  5. Paper space Model space ??
    By cncadmin in forum Autodesk
    Last Post: 05-29-2003, 12:07 PM
