586,121 active members*
3,156 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Preferred stepper motor type for a door lock
Results 1 to 9 of 9
    Aug 2010
    Red face Preferred stepper motor type for a door lock
    pls I am looking for a stepper motor type to drive a gear train which in turn drives a rack that drives a bolt to lock or unlock a door.I do not know how to go about the calculations on torque,speed , step angle,back emf, infact everything. I need help.
    its about my project:SMS controlled electronic door lock.
    pls everyone.say something.anything useful.Thanks.
    you can check my intended design.
    Attached Files Attached Files
    Dec 2007
    362
    The design seems overly complex.
    How about a simple solenoid to operate the bolt?
    Regards
    Geoff
    Jan 2010
    485
    Look at these; http://www.anaheimautomation.com/pro...ist.php?cID=52
    Do a google for linear stepper motor . They are on ebay and some of the electronic surplus stores have them too.
    On this type of motor the shaft is threaded and the inside of the motor is a nut. The shaft moves in and out instead of turning.
    Aug 2010
    Unhappy
    Thanks Packrat for the info. Still I like to ask.How would this linear stepper motors fit into my design. Pls I need some explanations if you don`t mind. Thanks.
    24221
    I would agree with Geoff, do you really need a stepper motor when a simpler mechanism would do it.
    The start and end position appear to be defined and fixed, so why a stepper?
    A bit higher cost than a simple spring loaded solenoid is a Shot Bolt, if it is security you need.
    Al.
    Albert E.
    Aug 2010
    Thanks Tumutbound for the idea. How and where do you think the solenoid would fit into my design? Please I need your help. Thanks again.
    Aug 2010
    Smile Still on the choice of stepper motor
    I have done some calculations but i am not sure if what I did is realistic. Its a bit much but please I just need someone to read it and give me advice. Thanks.
    Jan 2010
    485
    Quote Originally Posted by grandruby View Post
    The bolt would be connected directly to the shaft of the stepper I suggested. No gear train is needed, it moves in a straight line(linear).
    A solenoid is usually limited in the amount of movement it can make. Plus a solenoid would have to be triggered both to open the door and close the door. most solenoids are spring loaded so it returns to the extended position when the power is released.
    24221
    Albert E.
  1. Mazatrol Dual Turn Fusion 640T (Door lock question)
    By Sammeh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-22-2010, 04:06 PM
  2. type stepper motor 42BYGH06004-12
    By T-cue in forum Stepper Motors / Drives
    Last Post: 09-03-2008, 09:44 PM
  3. stepper lock new build
    By dgalaxy in forum CNC Machine Related Electronics
    Last Post: 04-02-2006, 09:04 PM
  4. Preferred Stepper Driver Electrical Interface
    By JeremyLee in forum Polls
    Last Post: 02-26-2006, 10:08 PM
  5. what type of stepper motor to use
    By landart in forum DIY CNC Router Table Machines
    Last Post: 08-27-2003, 04:48 AM
