586,035 active members*
3,769 visitors online*
Results 1 to 9 of 9
    Jul 2010
    which M code all spindles down!
    Hi everyone,
    I have a machine HEIAN 431p (Fanuc Oi-MC). I know M11 spindle #1 down, M21 spindle #2 down, M31 spindle #3 down, M41 spindle #4 down. M92 all spindle up. M95 all spindle off.
    Who can help me how to do all spindle down?
    Feb 2009
    6028
    If there is no one mcode to do it all, simple write a 8000 macro with all the mcodes you need and assign it to an mcode.
    Jul 2010
    Thank you under,
    I think so., but what do i do now? Do you know parameter for this machine? I dont know unlock macro system program.
    O8000;
    M11;
    M21;
    M31;
    M41;
    M99;
    What is the position in system parameter?
    2932
    If you can find an unused M-code, i.e. M51, put that value (51) in one of the parameters 6071 to 6079. Some of these may already be used by the MTB, so find one that doesn't have a number in it.
    Let's say 6077 is 0 or blank (I don't remember which it is). You set it to 51, and rename your O8000 to O9007.
    Now, when you command M51, it will execute O9007 and bring all 4 spindles down, then return to the main program.
    Jul 2010
    I am using AlphaCam mill program,
    That is Fanuc 6MB
    When i set T=1, machine works with spindle #1
    When i set T=2, machine works with spindle #2
    When i set T=3, machine works with spindle #3
    When i set T=4, machine works with spindle #4
    When i set T=5, machine works with spindle #1 & #2
    When i set T=6, machine works with spindle #3 & #4
    When i set T=7, machine works with spindle #1 & #3
    When i set T=8, machine works with spindle #2 & #4
    2932
    Quote Originally Posted by dung_ninhbinh View Post
    That is Fanuc 6MB
    I don't understand. How does this relate to your original question??? You asked for an M-code to bring all spindles down on an 0i-MC...
    Jul 2010
    sorry, our company has 6 cnc machines. 1 fanuc 6MB, 1 fanuc 18M, 1 Xilog3, 1 Fanuc Oi-TC, 1 Fanuc Oi-MC, 1 Bacci 5 axis.
    Sep 2008
    138
    Hi
    Hi everyone,
    Do you know your CNC had PLC in side Fanuc controller or Heian use PLC out side of Fanuc controller. If Heian use PLC inside of controller you can find M-code by view ladder. If Heian use PLC out side of controller you must know which PLC was used by Heian and use special software of manufacture who made this PLC to load ladder and view it then you can find M-Code
    May 2007
    15
    I have a fanuc OM and M91 is all spindles down.
    Hope it helps
  1. Any reasonably priced (cheap) spindles other than the chinese spindles?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 11-05-2014, 11:16 PM
  2. Spindles
    By wcarrothers1 in forum DIY CNC Router Table Machines
    Last Post: 02-13-2009, 05:46 PM
  3. HF spindles
    By endgrainguy in forum CNC Machine Related Electronics
    Last Post: 09-29-2008, 07:00 PM
  4. Air spindles
    By sizmo in forum Toolgrinding / Toolgrinding Machines
    Last Post: 12-17-2007, 03:06 AM
