586,089 active members*
3,836 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > Fagor 8055TC tool change position in Cycle mode?
    Sep 2009
    7
    Hi from Germany
    i got a problem with the toolchange position !
    where can i change the position for the toolchange when i use buildin PLC canned Cycles
    Programm 3-Part4
    1 Zylindercycle
    2 Zylindercycle
    3 treadcycle
    wher can i set there the toolchange position
    the manuel say you need to edit the sub programm
    wher is P60 my parametertable starts on P100
    is this the right way to do this?
    P60 "TOOLSUB"-> P60 "TOOLSUB" = 55
    programm 99999997
    (SUB 55)
    (P100 = NBTOOL)
    (P101 = MS3)
    G0 G53 XP?? ZP?? where ?? are the numbers from the reference point
    M5
    M0
    (RET)
    Mar 2008
    169
    In conversational mode or in the convencional mode?
    Sep 2009
    7
    i finaly found the problem wars Maschineparameter 60 not in use cause P100 wars 0 has to be 1
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  3. MV-45/40 tool change arm out of position
    By vfsi in forum Mori Seiki Mills
    Last Post: 01-01-2014, 10:28 PM
  4. mtm tool change position
    By double a-ron in forum GibbsCAM
    Last Post: 01-24-2010, 06:29 PM
  5. tool change position
    By miand in forum OKK
    Last Post: 09-28-2009, 02:02 PM
