Hi Pippin - Please direct these papers to me sounds interesting. Often these tests us cantilevered samples that in no way represent how the member is used in a machine. I feel its only adding mass which is then a bit harder to excite. There are many videos of hitting open and filled tubes with hammers to "prove" they are damper. This does not prove they are damper in a machine application unless you are hitting things with hammers. Machines are under very very low strains and those sort of tests are high strain tests. Peter
Hi Hezz - In my Milli thread I spend a year or so working through EG, UHPC, carbon fibre, glass fibre and metals and combos. I feel EG is a dead end for hobbyists. Too expensive and the modulus achieved is too low for the cost. UHPC is cheapest per volume but again is low modulus around 40GPa. Steel at 200GPa and cheap is very attractive and if you laminate it its damper then cast iron. Laser cut steel is a cheap and accurate process, then finish machine and your done. The inside of the steel layers can be tailored to an optimum shape.
Embedding a steel box into EG is in my view the wrong way to go. But get busy and make models to prove out a few things for yourself and get quotes for epoxy that will scare you. I buy epoxy at $22/kg or $22/litre AUD (3.5GPa stiffness
and I just had a quote for some aluminium 25mm plate at $40AUD per litre and its 70GPa and easy to machine. If you get the sand for free then the epoxy is not too bad but then you will only get 30-35GPa out of the material... So you need a lot of it to get to the same place as steel for a given geometry... Keep at it. If your machine vibrates its simply not stiff enough. Peter
Filling tubes with stuff is clearly the wrong approach. All aerospace structures are spider web type trusses. Fusion360 has generative design that will figure out the shape something should be at half the weight and same stiffness as the bounding box solution. Bambach did good work but that was over 20 years ago and we have moved on! Hobby builders are a bit obsessed with SHS and RHS and welding and fettling and damping, we have to move on way past that... and Hezz look up input shaping that the 3D printing industry uses. This is an approach that cancels structural vibrations using electronic damping. This is a much better strategy then material damping as it is a direct accurate method vs a splatter gun hope for the best approach via material damping. material damping will never be good enough for high performance low weight structures. If material damping was good enough we would not have shock absorbers on our car wheels we'd just have a slab of rubber. Rant ended....
