586,096 active members*
3,637 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > cutting speed and force required to cut 4140 with HSS
    Jun 2010
    60
    Question cutting speed and force required to cut 4140 with HSS
    I need to cut 4140 pipe.
    OD - 137.6mm
    wall thickness - 18mm
    With the beautiful piece of engineering you see in the attachments.
    It has 3 HSS blades(62-65HRC) that rotate out on pins. They are driven by a hydraulic piston down the center on a lever system.
    What I need is an RPM and a cutting force (which I can translate into required hydraulic pressure) to cut through the pipe.
    The blade at their widest measure Ø138mm
    Can anyone help me with a place to start.
    The main problem is it is DEEP down a hole so no visuals. Only a RPM and pressure guage
    Cheers
    Craig
    Attached Thumbnails Attached Thumbnails casing cutter assembly 1.jpg   casing cutter assembly 2.jpg   casing cutter assembly 4.jpg   casing cutter assembly 5.jpg
    May 2005
    2502
    If it was a single point boring head, you'd be running it at approx 50 rpm. Power required, which you can translate to a rough force estimate would be 0.0207 KW.
    Sure you wouldn't rather use carbide cutters? Should be pretty easy to figure some lathe inserts that can be installed on the swing out cutters. That would make your rpm more like 400 and the power required is now 0.1775 KW per cutter.
    For 3 cutters instead of a single point, the rpm will be the same. Power will be a little less than 3x, but assume 3x for the sake of conservatism. You'll want to consider how the 3 cutters will interact too:
    Are they all cutting along the same annulus, with each one cutting deeper like an endmill? Are they staggered along the bore with each a different depth?
    My rpm and power computations were done on G-Wizard and assumed an 0.1 mm depth of cut.
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Jun 2010
    60
    Thanks Bob
    The reason for the HSS was the instability. The body of the cutter has about 12mm a side movement. So the blades will have to guide and cut.
    I have the design for a set with carbide inserts all ready for machining.
    Thanks again for the help. Will let you know if it worked
    C
  1. Typical cutting force
    By Evilness in forum DIY CNC Router Table Machines
    Last Post: 01-17-2023, 03:14 AM
  2. Cutting force
    By vojnik in forum Mechanical Calculations/Engineering Design
    Last Post: 03-06-2010, 10:52 AM
  3. Cutting through the crust on 4140
    By jderou in forum MetalWork Discussion
    Last Post: 08-20-2008, 10:33 PM
  4. calculating expected max cutting force required
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 11-02-2007, 12:19 AM
  5. Cutting / Thust Force
    By juanca in forum Mechanical Calculations/Engineering Design
    Last Post: 09-15-2006, 02:00 AM
