I was looking to make a machine using unsupported rods(they're cheap and don't bent if short and thick). I looked at ground and polished rods and the clearance is +0.000 to -0.001 (diameter) and the bushings are -0.000 to +0.001 inches (innner diameter). what i was wandering is if .002 in diff in diameter is enough to prevent binding or if i should get sloppier bushings. There is a potential for even less than .001 in difference in diameter and I wonder if the rods bend at all it seems they would bind. I would be glad for any insight on this situation. P.S. http://www.speedymetals.com/ these ground and polished rods are cheap and precise.
