586,635 active members*
3,199 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Inactive "Virtual CNC Mill"
Results 1 to 7 of 7
    Aug 2010
    Hi, this is my first post here so hello to everybody!
    recently I've bought BobCad-Cam v23 with ART and Predator Simulation Level 3.
    I learning how to draw, create toolpaths and wanted to simulate the process but the option Virtual CNC Mill is inactive. In Licenses window, from Help menu I can see that there is license for Predator with correct level.
    What am I doing wrong?
    Cheers,
    expart.
    Sep 2009
    84
    The back-plotter isn't automatically installed, happened to me both at home and work
    programfiles/bobcadv32/system is the directory i believe the back-plotter's install file is saved in
    -Jacob
    Aug 2010
    Thanks, I can see it.. But now I've got another problem - during installation I'm getting the "Error 1904. Module C:\Program Files\Predator Software\Virtual CNC 7.0\PVCNC_Color.ocx failed to register. HRESULT -2147220473. Contact your support personnel."
    Then the same only for PVCNC_Light, PVCNC_Material, SlideColor.
    I'm working in Windows 7 32bits.. Maybe this is a problem?
    Dec 2008
    4548
    Here's a link to the Visual C++ redistributable that is needed here:
    http://www.bobcadsupport.com/tech//vcredist_x86.exe
    The installer should install all this stuff you have missing from your install session. Maybe with your setup, when you get ready to do an install, right clcik it and choose "run as administrator". This may have it do the proper install with all the requirments.
    Aug 2010
    Quote Originally Posted by BurrMan View Post
    Unfotunately it haven't help..
    Dec 2008
    4548
    Quote Originally Posted by expart View Post
    Uninstall both predators. Install the Visual C++ runtime from the link. Re-install both predators.
    Find this file and double clcik it: C:\Program Files\BobCAD-CAM\BobCAD-CAM V23\NC Verify\reg_ocx.bat
    Right clcik your BobCad Icon and select properties. On the compatability tab, select "xp", disable desktop composition and visual themes.
    Right clcik the BC icon and choose properties. Select "find target" (or got to location). Find the BobCAdV23.exe and right clcik it and select run as administrator.
  1. Replies: 12
    Last Post: 06-27-2012, 12:30 PM
  2. "motor steps per resolution" and "driver microstepping" settings
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-24-2009, 08:33 AM
  3. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2009, 04:48 PM
  4. "Warco GH Univ" V "Chester Lux Mill"
    By JQ_Quint in forum Benchtop Machines
    Last Post: 01-22-2009, 05:59 PM
  5. G320 "common" or "+5vdc" why do they vary?
    By beezerlm in forum Gecko Drives
    Last Post: 01-12-2008, 11:00 PM
