586,071 active members*
4,360 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Appropiate 24V power supply for Yaskawa SGDM servopack?
    Jun 2010
    Does anyone have any idea where I can get 24V "double shielded enclosure" power supply that is suitable for the SGDM.
    The manual does n't specify any kind of amperage but I'm assuming its not going to be much since it's for signaling but I guess it has to be pretty stable and emmune from interference.
    Anyone have any ideas?
    15362
    kbayram
    Just a regluar power supply work just fine, look at power-one, you need at least 1/2amp per drive
    Mactec54
    Jun 2010
    Thanks mactec,
    Those look like quality power supplies and don't seem to cost much more than the chinese imports you see offered on ebay that I was initially considering.
    I have 3 drivers so 2.5A should be adequate.
    On a related note would it be better to connect the AC supply before or after the AC line filter that supply the drivers?
    15362
    kbayram
    You don't need a filter on the AC that feeds the 24V Dc supply, just remember you may need more 24v DC for other things, so it is better to get bigger 4/6amp would be better
    Mactec54
  1. Yaskawa SGDM fault help needed
    By tommee10533 in forum Servo Motors / Drives
    Last Post: 05-06-2017, 08:37 PM
  2. Help with Yaskawa SGDM-04ADA-V ac servo drives
    By geebow in forum Servo Motors / Drives
    Last Post: 12-13-2015, 05:09 PM
  3. zero speed problem with servo pack Yaskawa SGDM
    By ferdi_mcrohl in forum LinuxCNC (formerly EMC2)
    Last Post: 06-01-2010, 02:40 PM
  4. Yaskawa servopack
    By Grubma in forum Servo Motors / Drives
    Last Post: 10-22-2008, 07:54 PM
  5. Yaskawa LX3 servopack alarm
    By crocnc in forum Servo Motors / Drives
    Last Post: 10-01-2008, 12:13 AM
