I'm in agreement with kineticstep and monstrum. Put a wire between the two select terminals and connect your AC pigtail cord to the AC IN terminals. The select jumper just reconfigures the input circuitry for the voltage you are operating the power supply on. It's equivalent to the red 110v/220v slide switches you see on PC power supplies and other modular power supplies.
If you are looking at the DC output with a voltmeter when you turn it on, it may not go to the correct output voltage until there is a small load on the output. It depends on the regulator circuit design.
CarveOne
CarveOne
http://www.carveonecncwoodcraft.com
