586,116 active members*
3,469 visitors online*
Results 1 to 13 of 13
    Jan 2009
    396
    PDS colombo and Giordano Colombo
    is PDS colombo the as Giordano colombo?
    where can I get RS 110 ISO30 - 2 10HP 7.5Kw 380V 200/400HZ 12000/24000RPM 17.5A 2Poles?
    Looks like it.
    Precision Drive Systems is the Exclusive Authorized Sales and Service Center for G. Colombo spindles in North America.
    Do you have 3 phase power to run it?
    ANd are you aware that it's probably at least $6000, not including the VFD?
    Jan 2009
    396
    yes I am aware of the price but I want to get the best, I am really sick and tired of the chinese 2.2kw spindle motor (I think it's a junk). I have 3phase in my place so no problem with that.
    Btw should I get the ISO30 or the HSK F63?
    and what other things I should get to run this kind of motor other than vfd? AC line reactor? air compressor? and that thing to measure and set the endmill to the tool holder what do you guys call that thing?
    Thank Gerry!
    The HSK toolholders are better, but cost twice as much as ISO30's.
    You do need clean, dry air for the toolchanger.
    We don't use a tool setter, we just make a test cut and measure to calibrate the tool length.
    Jan 2009
    396
    How is the HSK better than the ISO? is it more stronger, precision?? I don't believe they cost twice as much though.
    Is the tool setter expensive? and how do you measure the way you do? just make a test cut and measure the cut part???
    btw I was looking at FIMEC the other day they cost 3000 euro for the same unit.
    How good is FIMEC Gerry?
    I have an industrial air dryer for compressor and I think I would need air filter for air outlet?
    HSK's are shorter, and more rigid. I used ISO30's for the last 10 years, and they needed to be replaced frequently. I now use HSK's and like them much better.
    A tool setter is about $1000. I just measure with a tape measure to get close, make a cut, and measure. Only takes a minute.
    You'll probably want a tightening stand, like this.
    http://www.vortextool.com/index.cfm?...ategory_id=100
    and a torque wrench
    http://www.vortextool.com/index.cfm?...ategory_id=104
    Jul 2007
    1602
    HSK holders are more complex than ISO holders. They have two bearing surfaces: the taper and the back face of the flange. HSK holders don't use a pull stud and don't suffer from pull stud distortion issues. The high speed dynamics of HSK holders are better as well.
    Here is a nice brief write up I found: http://www.akhurstcnc.com/hskiso.htm
    There is a lot more information to be found by Googling.
    bob
    Jan 2009
    396
    thank you guys, but how about FIMEC? anyone knows the quality?
    oh and HSK F63 have short nose and long nose which one is better?
    and also do I need an AC LINE REACTOR between spindle motor and inverter the power is 7.5kw 380V
    The shorter the better.
    I've never seen a Fimec, and don't know if you need a line reactor.
    Aug 2010
    Is the tool setter expensive? I am really sick and tired of the chinese 2.2kw spindle motor.
    Welcome to my paintings website - www.wholesaleartmall.com
    Jan 2009
    396
    Hi angelababy what makes you sick of 2.2kw chinese spindle? I've got problems with them one of them is that when I'm cutting sometimes it just stop dead but the vfd keeps on going. I've look at the prices almost twice as much but don't know if it really worth it to go with hsk f63. the price difference of FIMEC vs COLOMBO is so obvious but they both are made in Italy. I think I would give FIMEC a try
    Jan 2011
    Aug 2007
    32
    I too am looking at a ATC system and considering Colombo 10 HP unit but have been quoted over 10K for the unit alone . After reading this thread I tried to have a look at the Fimec site but didn't get too far.
    What is the cheapest source for the Colombo units and is the Fimec equivalent better value?
    Peter
  1. FIMEC VS PDS COLOMBO
    By 15mgtar in forum CNC Tooling
    Last Post: 08-20-2010, 02:25 PM
  2. need help on a Colombo spindle
    By contactirfu in forum Phase Converters
    Last Post: 09-03-2009, 01:33 AM
  3. looking for pds colombo 10hp
    By Heinz helmut in forum Canadian Club House
    Last Post: 08-07-2009, 01:05 AM
  4. 3 HP Colombo Spindles Now Available
    By blurrycustoms in forum News Announcements
    Last Post: 03-17-2009, 08:23 PM
  5. Colombo burn out
    By Paul Petersen in forum Commercial CNC Wood Routers
    Last Post: 12-28-2007, 08:16 PM
