586,096 active members*
3,745 visitors online*
Results 1 to 6 of 6
    Jul 2008
    84
    Yaskawa analog problem
    i have a big problem with analog servo system .
    in digital driver, when pin S-ON is active, and dont have any pulse in input, we see that shaft motor is Motionless and LOCK(if we want turn shaft with hand , we dont can)
    but in analog drive, when i set 0V for input ,motor is motionless BUT i can turn shaft motor with hand.
    why?
    Amir
    Jul 2008
    84
    nobody ?
    Nov 2005
    256
    In digital mode, the servo drive's outer control loop is position control and it will keep the encoder count from moving. In analog control the position loop is disabled and the outer loop is just the speed loop. It will try to hold zero speed, but will not try hold position at all. You would need an external position controller to hold position by varying the analog input to keep zero position error.
    Jul 2008
    84
    is it possible more explain about external position controller for analog driver(speed control)?
    Amir
    Nov 2005
    256
    I'll have to leave that to someone else. If no one chimes in, you can google on Galil as an example of a manufacturer that makes motion controllers. Yaskawa also has them. As do others.
    Sep 2010
    Smile Call IES 678-341-8050
    they help us with all of our repairs
    678-341-8050 is their number or www.internationalelectronicsolutions.com
  1. Yaskawa ac servo encoder problem
    By Grubma in forum Servo Motors / Drives
    Last Post: 08-16-2009, 06:24 AM
  2. Yaskawa inverter problem
    By anandhs in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-21-2007, 02:27 PM
  3. Yaskawa Inverter Problem
    By Mert-G in forum Phase Converters
    Last Post: 11-22-2007, 05:09 PM
  4. problem with Yaskawa V7 drive
    By rebrumm in forum Phase Converters
    Last Post: 05-22-2006, 10:40 PM
