586,058 active members*
4,281 visitors online*
    Apr 2009
    19
    mill keyway with matrix control
    Hey guys, need some help mazatrol milling is my weak spot and im just trying to do a simple straight keyway on a mazak 350 lathe with a matrix control and with no Y. The endmill is to size and i just want to plunge on center and then move in Z with multiple passes on X. I am using a line center process, I closed both ends of the keyway I keep getting a tool interference alarm. maybe a brief explanation of how line center works would send me in the right direction. I have really good knowledge of mazatrol programming there is something small I must be missing. thanks any help would be appreciated!
    Aug 2005
    25
    let me see program?
    1)Move cursor to bottom left corner ( Right click, start menu, Left click explore)
    2)Find file mainte on C Drive
    3)Click on Printscreen3
    4)Go to program ( Area in program when you are programming issue )
    5)input USB drive
    6)Click save ( This will save to USB if you choose )
    7)Post info to fix problem
    If you can not do this call Mazak with issue.
    Lepton
  1. Alarm code 1224 on Matrix control
    By spartus333 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-23-2010, 09:28 PM
  2. DNC and Matrix control
    By golijoef in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2009, 01:34 PM
  3. Matrix Control
    By Mikiemo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-08-2009, 01:16 AM
  4. Probing and g10 questions matrix control
    By Liontastic in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-04-2007, 09:01 PM
