586,119 active members*
3,510 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > MX45VAE active tool pot orientation
    Dec 2008
    20
    Question MX45VAE active tool pot orientation
    This one is for older Okuma operators / owners:
    I've just started a job where I'm running an MX45VAE. Seems to run really well (apart from noisy X-axis slide-way covers).
    My question concerns the cylinder that controls the active-pot-advance-to-tool-change-position. It seems to be slow and a bit jerky, and the ready-for-tool-change proximity switch signal sent to the NC seems to happen a fraction too early as the tool change arm actually pulls the tool and pot a bit further towards vertical as it tool-changes.
    I've gotten around the time delay issue by loading the library file OTCHK.LIB that I copied from an old CNCzone post into the buffer. Works a treat!
    Anyway, has anybody had a failure or a degradation of proper function issue with these older Okuma's tool-change-pot-advance mechs? Should I look at servicing it or are they set up to orientate the active pot slowly (and rather clumsily)???
    Luke
    Dec 2008
    20
    I just re-read the first line of my o.p. What a tragic way of starting out a new thread :withstupi
    What I meant to say was: "This one is for anyone that runs / owns an older Okuma mill."
    I wasn't trying to be an ageist!
    Luke
    Mar 2009
    1982
    I would say, this tool-pot vertical issue is common for that age that model machines. plastic changes it's dimension - You can check measuring that, compare dimensions of some pots. Pot vertical guideways getting dirty. And, of course, moving parts including cylinder weakens.
    I applied one solution for some machines and it works great for (2 ... 4) years already. I just grinded the pot guiding plates a little so, that all of pots fits in easily.
    Some backlash is allowed there anyway.
    First of all, You need to be sure, that Your magazine adjustment and location of LS (SQ8, SQ9) is correct.
  1. Parameter for current active tool!
    By LVX in forum Fanuc
    Last Post: 03-04-2010, 08:23 PM
  2. Spindle orientation prob during tool change
    By CRABMAN in forum Cincinnati CNC
    Last Post: 01-25-2010, 07:55 PM
  3. Replies: 12
    Last Post: 12-31-2009, 08:34 AM
  4. Tool orientation in carousel.
    By 11toma in forum Fadal
    Last Post: 12-22-2009, 09:59 PM
  5. Active high vs. Active low
    By aaronkeit in forum Gecko Drives
    Last Post: 08-22-2007, 08:57 AM
