586,655 active members*
3,046 visitors online*
Results 1 to 6 of 6
    Sep 2009
    21
    Fanuc 0TC control retrofit
    Does anyone know of a retrofit for the Fanuc 0tc control so I may upload nc code off of a disc/ stick ? My lathe has the Fanuc cassette reader serial port but I don't have the hardware or software for it. I am memory limited and don't want to erase programs so I may write new ones.
    Please let me know if you have used or have a link to some one here who offers retros.
    Moto
    Dec 2003
    24223
    Have you thought of using RS232 with a PC or laptop?
    I have PM'd you re the memory.
    Al.
    Albert E.
    Sep 2007
    371
    I think the only solution is as Al says is to hook a PC to your lathe and upload/download the programs... I know lots of 0C controls and that is the only way I know.
    Greg.
    Jun 2006
    48
    fanuc 0TC?
    The way is a PC whit a communication software.
    By rs 232 port you can send and receive your program, and you can store it save ia a pc hard disk.
    I'm Italian and I use this system in my small shop for communication whit my 5 fanuc machine(one software fife machine!!!)
    For very large program(up 200k) you can use DNC function.
    I use a U.S.A made software it cost 50$.
    If your cnc dont have rs232 you can put it on.
    .......But 0iTc control don't have pcima port??? either way you can use it!!!
    Hi
    Dec 2003
    24223
    Depending on the present memory size, the memory can be expanded by setting an option parameter up to a point, after that an add on board must be also added.
    Al.
    Albert E.
    Mar 2005
    816
    Yeah, I use RS232 and DNC with my OM-C. Works great. Can store my programs offline in the PC. Don't nessisarily have to have all of your programs directly on the CNC/NC, but like for me I suggest storing the programs that you use the most on the CNC.
    My programs are a little bit under 200k most of the time on the OM-C.
    The shop I worked at had similar setups using Predator DNC. Worked great.
    Greg
  1. control retrofit, which one
    By chaz6966 in forum Cincinnati CNC
    Last Post: 11-04-2010, 10:32 PM
  2. CNC CONTROL RETROFIT FOR LATHE
    By WIRE CUTTER in forum Controller & Computer Solutions
    Last Post: 10-26-2009, 12:24 AM
  3. Retrofit Anilam Control
    By buff324 in forum Controller & Computer Solutions
    Last Post: 04-29-2008, 12:22 PM
  4. Okuma retrofit Machmotion control
    By KGD in forum Okuma
    Last Post: 04-23-2008, 04:45 AM
  5. SX3 spindle control retrofit?
    By Greolt in forum Syil Products
    Last Post: 02-07-2008, 02:20 PM
