586,477 active members*
1,908 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > CNC machine with manual control preserved
Results 1 to 3 of 3
    Sep 2007
    5
    I'd like to build a CNC machine for prototype work. However, I want to preserve the manual controls for basic operations. Also, I'd like to have a new machine, rather than find a used BP CNC or similar mill. And finally, I'd like to have a larger-size machine, rather than a pure bench top.
    What are my options? I was originally considering a full size knee mill and added a CNC kit later. However, it seems a lot of folks don't like this approach. Probably because it doesn't make too much sense economically. Currently, I'm considering a RF45/SX4 size machine. Does anyone make a kit for these machines that preserve the manual controls? Any advice or thoughts?
    Jan 2010
    100
    Instead of running hand knobs dials on the back of the servo's to move the table/head, and having to run a separate DRO on the machine for manual use this way (read around $600 for a DRO and glass scales),
    Run someone like Mach3 which has a built in DRO display screen for when the servo's are driven through the software/controllers, and control the servo's through mach3 manually with s selective axis dial pad for table/head movement for a couple of quick passes on your work piece.
    Aug 2009
    899
    marrt,
    There is no "kit" for the RF45 machines. I also thought I would want manual control, but once you get the machine under CNC you can add an MPG and manually jog each axis as if it were under manual control. I used this to manually cut parts on mine.
  1. Need a Machine Manual for a Comet Milling Machine
    By metalman7290 in forum Machinery Manuals / Brochures
    Last Post: 09-12-2020, 06:56 PM
  2. I NEED: DX-32 manual, 1104-2832 VMC Operator's Manual, DX-32 CNC Control
    By vettespeed in forum Bridgeport / Hardinge Mills
    Last Post: 05-31-2012, 02:21 AM
  3. Machine Builder Manual 0M control
    By davesnd in forum Fanuc
    Last Post: 08-17-2010, 06:10 AM
  4. Can Mach 3 control a partialy manual machine?
    By Scott Riddle in forum Mach Software (ArtSoft software)
    Last Post: 11-13-2009, 07:57 AM
  5. Manual and CNC Control?
    By Dave Berryhill in forum Charter Oak Automation Support Forum
    Last Post: 10-20-2009, 05:57 PM
