Hey Steven,
Good work also on the raptor stickers. From what I understand you have to setup the machine for the downforce. They must have some type of knurled screw that you turn to increase or decrease the force. You then have to cut a very small piece to see if it is set right. If all is well it will peel off with no problem. If you change the type of material (density, thickness, blade) then you have to readjust it. Maybe the really expensive ones are automatic.
taus
tauseef
www.cuttingedgecnc.com
