586,032 active members*
3,002 visitors online*
Results 1 to 10 of 10
    Mar 2009
    76
    Citizen Experts
    To all the citizen experts out there. When I am writing a program I want to tell the machine to only run back working if a part is present in the subcollet. Being that the collets are servo driven I am thinking this would be a simple IF#..............GOTO statement although I'm short on details. If anyone has any info on this it would be a HUGE help.
    304
    wORKS LIKE THIS
    M15(CLOSE-COLLET)
    G4U3.(#953-WAIT FOR VARIABLE TO UPDATE, MAY VARY)
    #500=12(ACCEPTABLE-#953 GOOD CLAMPING VALUE)
    IF[#953LT#500]GOTO953(COMPARE TO ACCEPTABLE VALUE)
    M98H1 (RUN BACKWORK)
    N953(JUMPED OVER BACKWORK FROM "IF")
    You may need this in multiple locations depending on the configuration of your program. Examp. multiple sub programs.
    Note: Clamping pressure varies slightly so allow some learning time to get it correct and have a dump before pickoff to avoid a crash due to a part being in the spindle.
    Mar 2009
    76
    awesome!
    thanks for the input.....what exactly is the 12 do you know?
    Mar 2009
    76
    would this work the same way on most citizen machines with a mitshubishi control?
    Aug 2010
    add a question, if fanuc system like A20 etc, how to work. thank you
    Jun 2010
    49
    servo collet closers
    The program for checking stock or part presence can only be done on machines that have the servo collet closers that supply feedback.The value of 12 is from the mc var# .That is what you have to look at when you do your set up to determine the number with a part and without one because that can vary from setup to setup.
    good luck
    304
    G-code is correct.
    You need to do your collet adjustment and then when it is where you need it to be, you go to the MC Var#953 for the sub spindle and see what value it gives you. Then check it again without a part in the spindle, open/close first, and pick a number between the two. You may get some false readings if you do not allow enough of a dwell!!!!!
    Yes this is for the Mitsubishi controled machines with servo chucks. The A20 is NOT a servo controled chuck. That is one reason it costs less than an L20.
    Aug 2010
    I tried this on a m16 and m12's for a safety check on the main spindle and found that to get it to work so it doesn't alarm out everytime after running on continuous that at the beginning of the program I have to clamp, dwell for .5, un clamp dwell for .5, (not sure if the dwell are necessary) and re clamp then use IF[#952LT5.]GOTO. In testing I tried to exceed my dwell up to 6 seconds and made no difference still would do the GOTO. If anyone has any info on why it does this would love to know Thanks.
    Feb 2011
    Block delete $1 and$ 2 g821 and g820 lines.. go in parameters and take off $1 single cycle start.
    Oct 2009
    84
  1. Any Macro experts here?
    By CarbonKevin in forum Solidworks
    Last Post: 07-07-2010, 06:54 PM
  2. Any YAG experts around?
    By dar303 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-31-2008, 07:27 PM
  3. Need Help from the experts
    By studysession in forum DIY CNC Router Table Machines
    Last Post: 01-09-2008, 03:00 AM
  4. Any AB PLC experts?
    By jderou in forum CNC Machine Related Electronics
    Last Post: 11-12-2005, 02:14 AM
  5. any pic experts?
    By posix in forum PIC Programing / Design
    Last Post: 07-01-2005, 08:27 AM
