586,116 active members*
3,474 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Lifting of OKUMA LB 10 lathe
Results 1 to 3 of 3
    Apr 2013
    12
    I would like to transport my Okuma LB 10 ii M lathe to a new location but I do not have lifting hooks for it. I am looking for drawings of the lifting hooks from okuma or just pictures of what they look like.
    Dec 2008
    3109
    Re: Lifting of OKUMA LB 10 lathe
    I would think that they use a decent fork truck, machine is about 3.5 tonne, so you need one that can lift that weight.
    If you are to sling it by crane, don't attach to spindle chuck or tailstock, see if there is holes in the bed casting for shackles. Don't allow sling to put any pressure on the outer cabinet as it would distort it.
    Mar 2009
    1982
    In the case if no fork lift available, soft lifting belts through the bottom of casting allowed for this machine.
    Apply fixtures for turret X and Z. Fix tailstock also. Empty hydraulic oil tank and coolant system.
  1. Lifting Tormach lathe from pallet without lifting kit
    By Spiffy Lab in forum Tormach Slant Lathe
    Last Post: 01-02-2020, 06:20 PM
  2. Okuma lathe help
    By rustedhooks in forum Okuma
    Last Post: 12-16-2018, 06:53 AM
  3. need help with okuma lathe
    By megastoogie in forum Okuma
    Last Post: 09-24-2014, 07:50 PM
  4. lifting a 12x36 lathe
    By casta-baga in forum MetalWork Discussion
    Last Post: 12-12-2009, 07:00 PM
