I need a lathe post for gibbscam, can anyone help out?? The control is a MSC-500 it is like a regular Fanuc type G&M code. So any lathe post will be fine. I will edit it if necessary with posthaste.
I meant to say I will edit it with compost, for all the post buffs out there.
Send contact info most any fanuc OM /MT will do!
Thanks I know most any will do. I did manage to get one that is close. Would you still please send me what you have to: [email protected] Thanks alot Jim!
Msc500 is Fanuc 21 or 21i
MSC-500 is just like 21I, come on dudes, I need that post. I want one that starts like this if possible:
O4545( STAINLESS STEEL SHAFT.NCF )
( STAINLESS STEEL SHAFT A REAL DEFEATER
( 7/23/10 AT 7:37 PM )
( OUTPUT IN ABSOLUTE INCHES )
( OPERATION 2: ROUGH )
( TOOL 5: 0.03125 RAD. 80-DEG. DIAMOND )
( 432 CNMG STYLE ROUGHER )
N1
G99G54
G30U0.
G30W0.
G50S850
G97S734M3
G0T0505
G0X3.Z.075M8
Z.045
X2.015
G1X1.432F.01
G96S275
Z-.0052
G3X1.4504Z-.0125R.0513
G1X1.547Z-.0608
G3X1.562Z-.0703R.0513
G0Z.0385
X1.3628
G1Z.0025
X1.3779
G3X1.432Z-.0052R.0513
G1X1.4968Z.0272
G0X1.4983
X1.8852Z-.1663
Z-4.3249
G1X1.885Z-4.325
Z-4.5133
X2.Z-4.5708
G3X2.015Z-4.5803R.0513
G0Z-4.325
X1.755
G1Z-4.4483
X1.885Z-4.5133
G0Z-4.325
X1.625
G1Z-4.3833
X1.755Z-4.4483
G0Z-4.3251
X1.577
G1Z-4.3692
G3X1.6234Z-4.3825R.0513
G1X1.625Z-4.3833
G0X3.
Z.075
G97S365
G30U0.M9
G30W0.M5
G0T0500
M1
( OPERATION 3: HOLES )
( TOOL 9: 0.468 DIA. DRILL )
( .468 TWISTDRILL )
N2
G99G54
G30U0.
G30W0.
G50S850
G97S650M3
G0T0909M8
G0Z.075
X0.
G1Z-2.005F.003
G0Z0.
Z.075
G30U0.M9
G30W0.M5
G0T0900
M1
( OPERATION 4: ROUGH )
( TOOL 11: 0.01563 RAD. 80-DEG. DIAMOND )
( 21.51 CCMT STYLE ROUGHER/FINISHER )
N3
G99G54
G30U0.
G30W0.
G50S850
G97S850M3
G0T1111M8
G0X.468Z.075
Z.0775
G96S275
G71U.016R.016
G71P4Q5U.015W.0025F.01
N4G0X.6574
Z.075
G1Z0.
X.6488
G2X.5984Z-.0104R.0356
G1X.5219Z-.0487
G2X.501Z-.0739R.0356
G1Z-1.8656
N5X.468
G0Z.075
G97S850
G30U0.M9
G30W0.M5
G0T1100
M1
( OPERATION 6: CONTOUR )
( TOOL 7: 0.03125 RAD. 55-DEG. DIAMOND )
( 432 DNMG FINISHER )
N6
G99G54
G30U0.
G30W0.
G50S850
G97S813M3
G0T0707M8
G0X3.Z.075
Z-.0449
X2.015
G1X1.6451F.01
G96S350
X1.5478Z-.0735
G2X1.532Z-.0633R.0513
G1X1.4354Z-.015
G2X1.3629Z0.R.0513
G1X1.4754Z.0331
G0X1.4887
X1.6433Z-.0442
Z-.0454
G1X1.5478Z-.0735
G3X1.562Z-.0995R.0513
G1X1.6548Z-.0722
G0X1.6723Z-.081
Z-4.3375
G1X1.562Z-4.37
Z-4.3717
X1.6748Z-4.3385
G0X1.6767
X2.0981Z-4.5492
Z-4.5549
G1X2.0008Z-4.5835
G2X1.985Z-4.5733R.0513
G1X1.6084Z-4.385
G2X1.562Z-4.3717R.0513
G1X1.6626Z-4.3421
G0X1.672
X2.0963Z-4.5542
Z-4.5554
G1X2.0008Z-4.5835
G3X2.015Z-4.6095R.0513
G0X3.
Z.075
G97S465
G30U0.M9
G30W0.M5
G0T0700
M1
( OPERATION 7: CONTOUR )
N7
G99G54
G30U0.
G30W0.
G50S850
G97S850M3
G0T1111M8
G0X.468Z.075
Z0.
G1X.6488F.01
G96S350
G1X.5219Z-.0487
G1Z-1.8656
G0X.468
Z.075
M9
G97S850
G30U0.M9
G30W0.M5
G0T1100.
M30
Also notice the R values in the G02, G03 lines they are not I J and K values, so the preparatory commands and the G30's, G54's, and G99 are musts.
I would appreciate anything that post close to this, in return I have I least 50 posts I can give, just give me a example of what you need and I will find something close.
Thnx
J
Please send posts to [email protected]
that is jayz(underscore)[email protected]
Thanks dudes!!!
J
Okay whoever sent me the post: Fanuc OT MS(+G30)l212.82.1.pst was really, really close. I will have to take it.... I just don't like how it posts the G30 lines like G30U0W0; instead of like G30U0; then G30W0; like my example but that was close like I said..... anyone got it the other-way?
Dude -
You said you had compost.
That change should take you all of two minutes.
Dude, don't worry already done! check the dates of the post Man.... Thanks for nothing.
Dude -
I did check the dates - no reply to if anyone had it "the other way".
Typically when you want something for nothing - lol.
