586,110 active members*
3,212 visitors online*
    Feb 2005
    487
    Bleeding Edge Mach3 CNC Operators Panel......
    Greetins,
    Here is a pic of the prototype of my "Night Vision" CNC Control
    >>pic is here at this link: http://www.machsupport.com/forum/ind...c,15759.0.html
    Operators Panel. It is a Flash screen that the "Soft Keys" below the screen, activate the function key above it, and the functions can be scrolled left and right, the 8 buttons to the right handle PAGE navigation. Simular to the way that Fanuc and Siemans do thier screens, the screen is also a touch screen. I put the "Mach3 CNC Keys" (powered by PoKeys) and the pokeys handles the screen function and navigation buttons as well and also it handles the 3 POTs: FSOVR, SSOVR, and JSOVR. The Estop and On/Off goes to a DL205 PLC for overall external systems control.
    this one has a Smooth Stepper, (but it could easily use a Galil as well), the DL205 PLC is hooked to Mach3 via TCP Modbus and it Mach3 talks to it, and it talks to the 5 ONE KW AC servos, and 3hp VFD, in a 485 net work, the Drive and VFD parameters can be monitored, and read/write from Mach3 on the fly. The PLC has 96 inputs, 64 outputs, 8 analog in, 4 analog out, an EXTRA 2 axis independant axis control card, for a Read-A-Head-Swap Arm ATC, and Pallet changer, and ECOM100 modules. The PLC also controls Spindle chiller, Cabnet Temp control, coolant, mist, swarf convayor, auto oiler, tool setter, door safties, Stack light, internal machine lights and all the IO for the ATC and Pallet changer. It has scripts for single and auto-multitool hiegth setting.
    The serial Modbus brings in the MP-03 "Pendant kit" pendant from Peter Holman.
    this is the control panel that goes with the 5 axis Mill panel that you saw the video on.
    [nomedia="http://www.youtube.com/watch?v=YcfzbLqG-VA&feature=channel"]YouTube- 5axisStage1big[/nomedia]
    I will be selling these, as well as "Simpler" Turn Key versions that have all the Operators Panel stuff, Except the function and page navigation buttons below and to the right of the screen. The Higher End screen like the comples one above, will be on a machine x machine basis, since it would need to be integrated into more complex OEM and Commercial Machines....... "Simple one" could also be done this way....
    As I finish the Enclosure (the pic is just of the Surface Panel), I will get more pics and vids up of the monster.......
    Scott
    Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/
    Apr 2006
    3498
    A great control panel and really looks professional.. thanks for sharing
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Feb 2005
    487
    Thank you for looking!
    scott
  1. Replies: 0
    Last Post: 06-30-2010, 05:06 PM
  2. Replies: 3
    Last Post: 05-14-2010, 09:16 AM
  3. edge finding with Mach3
    By wjfiles in forum Mach Software (ArtSoft software)
    Last Post: 03-08-2010, 06:27 AM
  4. Mach3 Touch Panel - Video
    By ozan in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-29-2008, 11:28 PM
  5. Ideas for Nagamura operators panel.
    By Jonne in forum Mach Wizards, Macros, & Addons
    Last Post: 12-05-2007, 09:31 AM
