The mechanical heart and soul of every machine is its linear guides. If your on a tight budget the first thing I suggest is scoping out ebay for at least a couple weeks to get an idea of what type of linear bearings you can afford. Theres no point in buying plans untill you are firmly decided on what type of linear guide system you can afford. Search for THK, IKO, INA, Linear, CNC, Slides and see whats out there and what you can afford. Of course if you want to make your own, or follow someone elses plans, this is unnecessary. But with the right strategy and some luck, you could snag three sets of THK or IKO linear rails and trucks for around 100 bucks an axis, and then build a real machine with specs as good as any six thousand dollar machine. Also snag a pair of ballscrews, but dont spend more than 75 bucks each (for 3 to 4 foot) or maybe a hundred with a double nut. For around 125.00 you can buy them new from a number of sources. If you want to build "the cheapest machine" you can, though, I would think the JGRO design available here for free is as good as anything youll find anywhere at any price. Its flexible and as low cost as it gets. Have you checked it out?
Halfnutz
