586,416 active members*
3,900 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Cable for programming Yaskawa SGDB Parameters
    Jul 2009
    28
    I found a document on the forum here detailing the programming addresses and commands using a PC and it also shows you the cable pinout but it is for a Yaskawa SGDA and I have Yaskawa SGDB. Would it be the same or where can I find one for the SGDB/
    Geoff
    Nov 2005
    256
    Per the manuals, both the SGDA and SGDB use a Yaskawa cable number DE9405258, so you can use the pinout you found.
    Jul 2009
    28
    Thanks, I found some software on the Yaskawa site also.
    Geoff
  1. UHU programming cable
    By cncfreakcom in forum UHU Servo Controllers
    Last Post: 03-22-2010, 09:45 PM
  2. Yaskawa Cable
    By liquidweb-test in forum Servo Motors / Drives
    Last Post: 02-10-2010, 01:50 AM
  3. Cable Pinouts-Parameters Nisshinbo
    By havnfunwrkn in forum Controller & Computer Solutions
    Last Post: 07-08-2009, 03:01 AM
  4. Tree Yaskawa Spindle Drive Parameters
    By BPT Man in forum Tree
    Last Post: 12-15-2008, 01:39 AM
  5. setting parameters through programming
    By bholbrook in forum Uncategorised CAM Discussion
    Last Post: 10-19-2005, 01:57 AM
