I’m new here, to CNC (I am truly a newb to CNC with solid technical skills and no experience) and certainly glad that I found this forum. I’m looking for some help / input / advice on an issue. I’ve recently bought a business that produces aluminum products out of flat sheet. The core of the production process is a Thermwood C50 router with two 15 HP heads, built in 1988 and the hour meters report about 10,000 hours. The controller is a 9100 series Cartesian 5 beast that is based on a 286 processor with about 640k memory. We use this router to cut different blanks or profiles from fairly thin (0.040 to 0.090) Aluminum sheet – where we then form the items with press or box brakes.
My problem is this – all of the existing programs were written by hand, that is the previous owner wrote the G code. The programs were written in an incremental format. When we bought the business, the first order of business was to buy a CAD/CAM package and start pulling the old designs into a package that would allow things to be easily manipulated. The CAD/CAM (BobCAD) package writes G code in absolute positioning and we find that the Z and W axis starts to lose its resolution and slowly start to eat into the table about 1/3 to ½ way cutting down a 12 foot sheet of aluminum.
We did find that there was a very simple backlash compensation move that was in the Z and W axis that we incorporated into the post processor which seems to help somewhat – but after running a couple of sheets it start to drop again. The funny thing is that on this old controller – the position doesn’t drop; it reports the correct depth even while it’s obviously off. Additionally there is some slight “jerking” (for lack of a better word) sometimes when the gantry changes direction in the x axis and y axis. (hard to tell which when the machine is making parts) Slowing the machine down minimizes this issue. There are ball screws on the Y axis (across the gantry) and Z and W Axis (routing and drilling heads) X axis is rack.
I fear that the controller could just be toast – my posted G code programs to cut parts is much longer than the hand written subroutines of the previous owner and I’m wondering if I’m just asking too much of the DOS based system with limited memory. OR I’ve got serious ball screw issues – though I’d think the old programs would be affected by this also. The old programs still seem to produce decent parts – though they are way inefficient and time consuming (many require the repositioning of material).
I’ve talked to an aftermarket controller manufacturer who states that my issues could be cleared up with the a new controller that has systems built into the software that would eliminate my backlash and inconsistent movement issues. Can a controller do that? Any help or input would be greatly appreciated. Thanks!
