I have been having problems with a new machine I picked up. I am running servos and Wincnc. After setting it up I have everything working properly other than the Z axis wants to drift up about .050 after a run time of about 30 minutes. It slowly trends upward as the program runs on, it is not just a sudden move. I have adjusted the revolution setting in the ini file for Z and it seems to be within .005 when I check the height. Is it possible that this needs to be closer than .005? Could my Z axis encoder be bad? Bad Z axis drive?
My table has been shaved down and is level to the bit. If I cut only a couple of small parts I don't see any issues. It seems as though the more Z moves it makes the higher the Z axis will go over time. Any help would be appreciated. I need somewhere to start.
Steve
