586,080 active members*
3,667 visitors online*
Results 1 to 7 of 7
    Precise CNC Machining - Smaller Parts
    I must have an NDA signed prior to sending this out for quote.
    QTY is like
    100
    500
    10,000
    50,000
    Electropolish Stainless Steel 304
    This is a rush quote. Please email me your info so we can sign an NDA and I can send you some files.
    Tim Ruffner
    [email protected]
    Thank you.
    Tim Ruffner - DMLS (Direct Metal Laser Sintering) Guru
    http://gpiprototype.com and http://directmetallasersintering.blogspot
    Jun 2010
    We would sign the NDA if you are still looking for quotations.
    Thanks,
    Jesse Watkins
    Stuart Tool & Die Inc.
    600 N. Work Street
    Falconer, NY 14733
    [email protected]
    716-488-1975
    716-488-1977
    Seems nobody is equiped for this part
    All the quotes coming back nobody can do.
    NDA is right here. If you would like to sign it and fax or email it to me that would be great.
    http://gpiprototype.com/Main-pages/n...tomer-nda.html
    Tim Ruffner
    [email protected]
    Jan 2008
    449
    Would help if you gave a description of the parts, are they lathe or mill work?
    Mill work.
    Dec 2009
    14
    This is nagendra from India. Please reply whether or not I can sign NDA
    Thnks and Regards,
    M.Nagendra Kumar
    Srikar Engineers
    Apr 2007
    1955
    I am not quoting on the job, but a couple of things might help if you can provide it:
    - Approximate part size - such as "2 x 2 x 5 inch cube size
    - How many axis of machining do you think the part will need to run it?
    - Smallest + deepest hole
    - Approx finish spec
    The great thing about the sintering process you are used to, is the flexibility to not worry about actually machining the parts. That can be a 2 edged sword when it comes to production.
    Are your local shops no-bidding the part as well ?
  1. Parts machining
    By mazaker in forum Hobby Discussion
    Last Post: 03-29-2010, 01:02 PM
  2. Machining parts
    By Susie in forum News Announcements
    Last Post: 01-11-2010, 04:12 AM
  3. MOST precise method of maching SMALL parts?
    By SRT Mike in forum MetalWork Discussion
    Last Post: 12-03-2006, 04:58 AM
  4. Machining anodized parts or anodize after machining?
    Last Post: 03-12-2006, 06:22 AM
