586,299 active members*
3,873 visitors online*
Results 1 to 1 of 1
    Apr 2005
    6
    Smile Sponge Roller (Foam Cutters!) RFQ
    Hello!
    I need a quote for 100 sponge rollers. Please look at the 2 attached jpgs.
    one image shows all the rollers removed from the sponge
    second image shows the sponge itself.
    Sorry for the bad image quality, I can retake it.
    These sponge rollers have a length of 40mm
    They have an external diameter of 27mm
    They have an internal diameter of 9mm
    All measurments can be -/+ 1.5mm
    The sponge has to be able to withstand a maximum of 60 degrees celsius with average operating temperature around 55 degress celsius.
    I can send a sample roller if it is required.
    I can also supply dxf drawings if req
    Also require postage to the Land of Oz (australia)
    One important note
    The rollers must not be split. I am not sure how the internal hole will be cut?? especially on a wire type cutter. But I'll leave that to the experts, - hence I am asking for RFQ.
    Kind Regards
    Attila
    'Don't ever under estimate the powers of an idiot'
