586,116 active members*
3,469 visitors online*
Results 1 to 12 of 12
    Aug 2010
    Keyway slotting
    Hi everyone,
    What is the best way to program for keyway slotting with a single point cutter.
    My first attempt is a 8mm keyway cut into a 25mm bore.
    Doosan 220LM / Fanuc 0i-TC.
    Have figured out the cutting stroke / speeds. How do you program the retraction & repeatition of the cuts with a sub. (nuts)
    Fast learner
    Aug 2009
    684
    Move to start position in main program.
    Call sub program with an G65 P(sub pgm no) L(number of repeats)
    Use incremental moves in sub program (G91) to perform one pass/retract/increment across.
    If you want to start getting clever you could add another couple of arguments to the G65 line to specify a. Total Depth and b. Depth of Cut. You would then remove the L and use logic (macro B) in the sub program to work out required no of repeats.
    DP
    Aug 2010
    Thanks for the response.
    You lost me after "move to......." I'll have to get my book out.........
    Got most of it.
    2932
    Your lathe doesn't use G91 for incremental. X and Z are absolute commands, U and W are incremental. Also, you can use M98 to call a sub G65 is usually used for Macro Calls. Lets say you want to make 20 passes:
    X24.5 Z2.0 M19 (POSITION TO START POINT, ORIENT SPINDLE)
    M98 P0201001 (CALL SUB O1001 20 TIMES)
    G30 U0 W0 (RETRACT FOR INDEX)
    M30
    O1001(SUB)
    G00 G98 U0.25 (RAPID UP 0.25MM IN X)
    G01 Z-25. F200. (FEED TO DEPTH IN Z)
    G00 U-0.20 (RAPID DOWN 0.2MM IN X)
    Z2.0 (RAPID TO START IN Z)
    M99
    Program O1000 will be called 20 times, each pass 0.05 higher than the last:
    X24.75
    X24.8
    X24.85
    X24.9
    X24.95
    Also, as christinandavid suggests, you could write a macro that does this a little more elegantly with variables, etc.
    Aug 2010
    DP,
    Can you give me an example to work on.
    Roger
    Aug 2010
    Spot on. Just what I was looking for.
    Roger
    Nov 2009
    7
    Re: Keyway slotting
    Hi i was reading your post and I'm trying to do something similar on sc200 naukamura. Can i use a g74 canned cycle.
    Nov 2009
    7
    Re: Keyway slotting
    Doing a 4mm wide keyway in a 13.992 bore depth of keyway is .075.
    thanks woody
    Nov 2009
    7
    Re: Keyway slotting
    working on sc200 naukamura
    Nov 2009
    7
    Re: Keyway slotting
    i figured out what i was doing.
    thank you
    Nov 2017
    Re: Keyway slotting
    Old thread but helpful, Thanks. Got my first slotting working with this, but I have a question. If i am making blind keyway without the relief, is there any options to retract the Z-axis with each pass? Lets say 0.05mm with each stroke. Just to slowly escape the chip build up. Machining plastics mostly.
    Using this piece of code
    M30
    O1001(SUB)
    M99
    Thanks in advance
    Mar 2009
    38
    Re: Keyway slotting
    Not entirely understanding your question. If you want to back off the bottom in Z just command it to do so in the sub program?
    I.E.-
    O1001(SUB)
    Z-24.95 (<~~~INSERT YOUR BACK OFF MOVE COMMAND HERE)
    M99
    Could also do it in incremental too (W.05)
    Personally, I would've used Macro to program something like this with a plane rotation command and WHILE/DO/END loop, but that's just me.
  1. Male keyway?
    By peter.blais in forum MetalWork Discussion
    Last Post: 01-29-2015, 08:25 AM
  2. Taper in keyway.
    By madmax99 in forum G-Code Programing
    Last Post: 07-17-2013, 05:49 PM
  3. Using a Keyway Cutter
    By helicaltools in forum Surfcam
    Last Post: 07-03-2008, 08:20 PM
  4. Keyway Broach Set
    By phoodieman in forum Uncategorised MetalWorking Machines
    Last Post: 05-28-2008, 11:04 PM
  5. Keyway or not to keyway... That is the question
    By jessbussert in forum Stepper Motors / Drives
    Last Post: 12-16-2007, 02:14 PM
