586,119 active members*
3,596 visitors online*
Page 2 of 4 1234
Results 21 to 40 of 69
  1. #21
    Mar 2008
    80
    Quote Originally Posted by P.Passuello View Post
    For what it's worth, I do know there is a special mat cutting router bit made for cutting mats. That would be the easiest solution for cutting mats as nothing special would be needed other than the bit.
    The problem is I can't remember who it was that sold them and you had to buy 10 at a time. If I remember I will let you know or someone here may know.
    Cheers
    Peter
    Hi Peter,
    Do you happen to remember anything about the shape or design of the bit? I'm curious how they keep it from burning or fuzzing up the mat board.
    Gordon
  2. #22
    Mar 2008
    80
    I've actually seen these machines in person, they're used to cut boat sails. A small stepper rotates the blade holder.
    http://www.carlsondesign.com/#Plotter_Cutters
    The cutting heads look pretty simple. I don't think they make any oscillating cutters.
  3. #23
    Mar 2006
    489
    Hmm, I should get into that business, 30k for a simple track and cutter head. They are using belt for the drive system too, wonder what they used to glue it down to the rails?
    I still don't like the idea of mounting a blade directly on the stepper shaft.
    My design in almost done...don't tell my boss.
  4. #24
    Mar 2006
    489
    Ok, so here's my take on it.
    Let me know what ya'll think...
    P
    Attached Files Attached Files
  5. #25
    Jul 2010
    159
    That looks AWESOME, can i have your brain lol so when are we going to design it? here is a picture of what the picture framing CMC machine blades look like
    except they slide in at a 45deg to do bevel cuts
  6. #26
    May 2007
    250
    Smile information
    MomentZ,
    This project is interesting. Here's the information. It may help you.
    http://www.cnczone.com/forums/showthread.php?t=26128
    http://www.comagrav.com/oscillating_...ial_knife.html
    I know the A-axis of mach3 can rotate the knife.
    I am not sure what cam software is suitable for the tangential cnc machine.
    What do you choose cam-software?
    Mongkol
  7. #27
    Mar 2006
    489
    Mongkol, thanks for the links.
    In the first link, ger21 says Mach3 will do tangential control only for G1 commands, but I think this has changed. I wrote a simple program to cut out a rectangle with rounded corners and it handled the G02 and G03 curves fine, although this was just a simulation since I don't have a tangential axis yet.
    The Comagrave is a pretty nice machine. I think I could design in an oscillating tool holder by adding another through shaft that is keyed inside the main shaft. This would add a fair bit of complexity, but could be done.
    Yes, to use tangential control, you install another motor driver as the 'A' axis. There's a button on the settings screen to put Mach3 into tangential control, and that's it. The 'A' will rotate according to the cutting path.
    As far as software goes, Sheetcam would work fine. Just use zero offset paths and away you go. I think the trick is to get the cutting tip exactly on the 'A' axis rotation.
    Overcutting isn't handled by Sheetcam as far as I know, so this would have to be drawn in as part of the .dxf.
    I'm pretty pumped about building this little machine. I just finished a CNC rotary table a few months ago, and this will be very similar as far as components and control.
    How many should I make? Is anyone interested in buying a completed unit or just the full set of plans?
    Paul
  8. #28
    Jul 2010
    159
    Hi Paul that machine looks excellent but i think i will stick to trying to get a computerized mat cutter/router developed first and with the help of you guys out there i can already see it
  9. #29
    Mar 2008
    80
    Quote Originally Posted by fatal-exception View Post
    Paul
    I like the design, it looks well thought out.
    A couple of random thoughts...
    I wasn't sure the purpose of the pigtail (# 220) in your drawing. At first glance I thought it a spring to preload the blade but based on position am I correct in guessing that it is a strain relief for your cabling?
    I'm not expert on bearing specs is DE,AC an angular contact bearing? Seems like a good idea here though probably not very imprtant for this application.
    Is the oscillating motion a high frequency/low amplitude motion? I think I recall seeing something about 3,000 cycles and travel anywhere from 2-10 millimeters depending on the material being cut.
    The knife blades used in these machines seem to be either thin xacto type blades or much heavier cylindrical sections with cutting edge machined on the end. Are these heavier blades used only for oscillating cutters, are they for machines intended to cut thicker or heavier materials, or is their no such correlation?
    I think I recall reading someone having trouble using Mach's tangential support for cuts angled relative to Z. I guess this is needed in mat cutting to get a bevel cut. Apparently the Mach feature to lift Z at the correct angle didn't work corrctly, the blade was lifted straight up out of the bevel.
    Sorry if all of these thoughts don't apply to your application or design. We have a couple people on this thread trying to do different things so I thought it useful to put these all together in one place.
  10. #30
    Mar 2008
    80
    Paul
    Arrg! CNCZone just ate my reply post. I'll try again later. Nice job on the design. I'm interested in seeing what you would do with adding ocillating motion
  11. #31
    Dec 2005
    238
    Quote Originally Posted by gfc62 View Post
    Hi Peter,
    Gordon
    From memory it looked live a V Bit but I know from experience a standard cutter doesn't work.
    Cheers
    Peter
    The ingenuity of idiots is unlimited.
    http://www.youtube.com/user/cncnutz
  12. #32
    Dec 2005
    238
    I have found the website and cutter I was thinking of
    http://www.thecmcdoctor.com/thecmcdoctor_blades.htm
    It is a US company so someone there might be able to investigate if it is a mat cutting blade and if it will work on a CNC router.
    Cheers
    Peter
  13. #33
    Jul 2010
    159
    got a call back from axyz, the tangential cutter as you know costs 16k WELL if you want the controller box aswell then it $35,000 with the cutter again YIKES,
    there is money in CNC's
  14. #34
    Mar 2008
    80
    Benz oscillating cutter head
    I saw this in one of the trade pubs covering the IWF show in Atlanta, an add-on oscillating cutter head for any CNC with tangential control.
    http://www.benz-inc.com/products_woo...w=detail&ID=56
    The Reciprocating Knife Cutter - RCK1
    is designed to add a new level of versatility to a "C"-axis equipped CNC machine. It utilizes a standard spoil board to hold material. During cutting with the oscillating knife cutter the spring-loaded floating ring ensures optimum contact of the material with the surface underneath. Similar to a jigsaw, very small radiuses can be cut.
    The very high reciprocating speed of up to 6.000 strokes per minutes ensures very effective machining with high federate speeds.
    The RCK1 is designed to cut cloth, fabric, leather, veneers, rubber, carpet, cork, vinyl, fiberglass matte, cardboard, linoleum and other similar products.
    not much info there but check out the video at:
    http://www.benz-inc.com/videos.php
    scroll down in the list of videos until you see the one
    titled "Benz Oscillating Knife Cutter"
  15. #35
    Mar 2006
    489
    That's looks NASA expensive. I'm sold on the spring loaded hemisphere hold down though...Gotta add that to my original design.
    Should be able to start making the unit early next week. All this 'after work' work is getting in the way!
    Paul
  16. #36
    Mar 2008
    80
    Paul
    With a name like Benz your tools have to be expensive!
  17. #37
    Jul 2008
    128
    A Axis Mach3 Angle Calibration
    How to calibrate A Axis to get the angle using Mach3 Settings menu Steps Per Unit button? Im using gear reduction to get the perfect angle rotation.
  18. #38
    Jul 2010
    159
    This was posted to me on joes forum, it looks like a simple design with just a blade holder on the end of a stepper motor, i was also in a framing store today watching some matts getting cut on a computerized mat cutter, and the z axis comes down the you hear a "PSST" and it shoots the blade in on a 45deg angle, there is an air compressor hooked up to it so i guess there is an actuator that shoots the blade in and out, i got thinking and thought back to my car central locking days and wondered if you could use a single car locking magnetic actuator and when you give it some current and it fires out and then reverse it, like what your locks do on you car by going up and down, any thoughts on that?.still following closly and the good ideas here.
    Don't know much about the topic.
    http://www.smp-sign-systems.com/produkt ... ser_e.html
    http://www.globalimaginginc.com/equipme ... ools.shtml
    http://lumenlab.com/forums/index.php?showtopic=25903
    This one looks very interesting and do-able :?:
    It is for a 24 footer :!:
    http://www.carlsondesign.com/#Fun_Shareware
  19. #39
    Oct 2008
    406
    You've got some incomplete URLs
    Bob
    "Bad decisions make good stories."
  20. #40
    Mar 2006
    489
    Moments, that sounds like the best idea yet for 45 deg cuts. It would take a little playing around to make sure the cuts all end up where you want them, but yeah, any way of extending and retracting the knife at an angle, independently of the motion control system, would be a decent solution. A small air cylinder hooked to a solenoid valve would probably be the easiest...
    I could envision making that an addon that would attach to the output shaft of my tangential axis design.
Page 2 of 4 1234
  1. Tangential knife project
    By Pragnellious in forum Community Club House
    Last Post: 02-09-2014, 04:46 PM
  2. Rubber cut with tangential knife
    By limacchina in forum Uncategorised WoodWorking Machines
    Last Post: 12-03-2012, 11:05 AM
  3. Tangential knife for my homemmade CNC
    By tsamael in forum Open Source CNC Machine Designs
    Last Post: 01-07-2012, 12:22 AM
  4. support for tangential knife??
    By SSN Vet in forum Mach Software (ArtSoft software)
    Last Post: 02-26-2009, 02:29 AM
  5. Add a tangential knife option
    By avengine in forum Community Club House
    Last Post: 04-13-2006, 12:40 PM
