586,103 active members*
3,304 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Router collet insert adapters
    Dec 2007
    17
    Hello,
    We have a CNC XYZ router with a Bosch spindle. It accepts endmills with a 1/4" shank. We have an assortment of endmills: mostly 1/4", 1/8" and 1/16". The router has a single collet which takes 1/4" shank bits. In order to use 1/8" endmills as well as 1/16" ones, we need either to change the collet or to use a collet bushing insert. Can someone tell me a single vendor which carries the 1/4" to 1/8" reducer insert as well as a 1/4" to 1/16" insert. I have only found 1/4 to 1/8 reducers and 1/8 to 1/16 inserts but no 1/4 to 1/16.
    Mike
    May 2004
    162
    Collets
    These work fine. Don't get caught up in buying "generic" ER-20 collets. They are not all the same. I have 1/8th, 1/4th, 3/8th, and 1/2". These are worth there weight in gold. You also need the nut and wrench from them.
    Thanks. Mike
  1. Losing router bit from collet
    By SteveS in forum WoodWorking Topics
    Last Post: 12-02-2010, 09:27 PM
  2. router collet add on
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 08-19-2009, 08:29 PM
  3. 1/4" Laminate Trimmer Collet Adapters?
    By vacpress in forum DIY CNC Router Table Machines
    Last Post: 02-26-2007, 06:09 AM
  4. Another Source for Collet Bushing Adapters
    By HayTay in forum DIY CNC Router Table Machines
    Last Post: 03-31-2006, 10:53 PM
