586,389 active members*
3,008 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Alignment of double sided work?
    Aug 2010
    Anyone have any good ideas on how to align the work after flipping it over? The Triforce I cut (http://fozztexx.com/CNC/IMG_3101.JPG) required me to flip it so I could recess the outer ring. Of course I didn't get it lined up quite right. I'm certain at some point I'm going to want to do double sided PCBs and it's going to be important that it aligns perfectly.
    What I did was I had it drill a hole on the right side all the way through so that I when I flipped it over the hole would be in a fixed position from the left side. Then I moved the tool out to that fixed location and lowered it and moved the work over to set the hole in the right place. But since the hole was drilled wobbly it didn't line up quite right. There must be a better way where I don't have to worry about holes being perfect.
    Apr 2007
    327
    Quote Originally Posted by FozzTexx View Post
    Alignment dowels or pins are the best way to flip something and maintain registration. If you can't use the holes you have drilled because they are "wobbly" then you need to improve your hole drilling capabilities.
    Aug 2010
    Quote Originally Posted by LaserImage View Post
    How would I make sure that my work is centered between the two pins?
    Jun 2005
    138
    I would make a hole in each corner, using a drill program to make the holes. Then when you flip the part, if 0,0 was the lower left hole, it could remain the lower left hole in the new orientation. Use pins or dowels to fix the parts to the holes.
    At a minimum, I'd drill 2 holes at a set distance along only one axis (say, along X). Then when the part is flipped, all Y-distances are still positive, but all X-distances would be negative.
    In either case, the distance from the tooling holes to any feature of your part is known, by design, and the part is rotationally constrained along at least one axis.
    May 2006
    42
    If Possible don't machine through your part on the first side, then try machining the side opposite of your X-0 Y-0 then when you flip the part you will know exactly where the part is.
  1. Double sided CNC router
    By Inventthis in forum Want To Buy...Need help!
    Last Post: 10-10-2008, 07:48 PM
  2. double sided hold down
    By ronateah in forum WoodWorking Topics
    Last Post: 11-07-2007, 01:30 AM
  3. Double sided tape
    By Greolt in forum CNC Tooling
    Last Post: 09-17-2007, 10:11 PM
  4. Double Sided Tape? Really?
    By kentavv in forum MetalWork Discussion
    Last Post: 12-03-2006, 05:47 PM
  5. double sided job setups
    By july_favre in forum Uncategorised MetalWorking Machines
    Last Post: 06-14-2004, 04:27 PM
