Normally you NEVER connect a R,S or T to ground.
The ground should be used as its name says and connect to the ground terminal, If you have 3 phase available from a convertor or? the RST go to the three terminal, it sounds like they used it previously on 1 phase, in that case R & S would normally work.
If it is a simple 3 phase full wave rectifier on the input then any combination of the 1 ph in would work.
Al.
Albert E.
