586,100 active members*
2,679 visitors online*
    Sep 2010
    Variable angle milling head
    Hello everyone,
    I am an engineer at a company in mid michigan and I am working on a machining project for some shafts that we just recently began making in house. The project is putting a keyway on a tapered shaft with a 5 degree angle. I would like to figure out a way to cut this key way without having to develop complicated fixturing to take the taper out as a factor (lifting the shaft to go from 5 to 0). Is there a variable angle attachment for the HAAS CNC that would allow me to set the mill bit at 5 degrees so that when I run the head up at a 5 degree angle in the program the end of the end mill would be parallel to the face of the shaft?
    *Oh; just so you all know a 5-axis table is definitely out of the budget*
    Aug 2010
    579
    Apr 2005
    713
    Can you use a keyseat cutter instead of an endmill and machine it from the side?
    Sep 2010
    Keyseat cutter might work
    It looks as though that Big Kaiser might work, I gotta read up!
  1. adjustable angle milling head.
    By Beek in forum Cincinnati CNC
    Last Post: 04-27-2010, 05:52 AM
  2. right Angle Head help
    By inkydo69 in forum Mastercam
    Last Post: 04-08-2009, 03:58 PM
  3. variable angle drilling head
    By kendo in forum Haas Mills
    Last Post: 12-12-2008, 05:46 PM
  4. Programing for Right Angle Head
    By bkobernus in forum Haas Mills
    Last Post: 04-27-2007, 11:31 PM
  5. Programming for angle head--G18/G19
    By Dave L in forum GibbsCAM
    Last Post: 07-21-2006, 04:33 AM
