586,075 active members*
4,028 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > EXTRA SPACES WHEN KICKING PROGRAM ONTO COMPACT FLASH?
Results 1 to 7 of 7
    Aug 2010
    188
    hello all, another rookie question here. why is it that when i kick a program from my cnc memory (31i fanuc) to my compact flash, the entire program is triple spaced? this makes editing on pc very annoying. not to mention when you re-load it back onto the controller the spaces stay in the program! this makes single blocking your newly edited program a real pain. is there any way to avoid this?
    ex; tripple spaced.
    X1.0 Y2.0;
    X2.0 Y1.0;
    X1.0 Y2.0;
    2932
    Check parameter 100 bit 2, (CRF), and 3 (NCR).
    100.2 (CRF) Output of the end of block (EOB) in ISO code
    = 0: Controlled by setting of 100.3 <---------- set 100.2 to 0
    = 1: CR, LF are output.
    100.3 (NCR) Output of the end of block (EOB) in ISO code
    = 0: LF, CR, CR are output
    = 1: Only LF is output. <------------- set 100.3 to 1
    So:
    If you set 100.2 to 0, you control EOB output with 100.3
    If you set 100.2 to 1, EOB will be output as CR, LF.
    If 100.2 = 0, then:
    If you set 100.3 to 0, EOB will be output as LF, CR, CR (extra blank lines)
    If you set 100.3 to 1, EOB will be output as LF.
    Aug 2010
    188
    AHHHH, it's pretty tough teaching yourself how to run a cnc with no formal training..... i think i know what i'm looking for but i'm pretty much lost when it comes to parameters. thanks for the help, i'll give it a try.
    Aug 2010
    188
    so what you are saying is i need to set:
    100.2 to 0
    -and then-
    100.3 to 1
    this will solve my extra lines problem? (sorry for being such a newb)
    Aug 2010
    188
    my controller tells me that this parameter is "write protected" WTF, any way around this besides calling the guy who set the machine up?
    2932
    You can unprotect the parameters as follows, but BE CAREFUL! Changing the wrong parameter can spoil your whole day.
    In MDI, press OFFSET/SETTING function key, then [SETING] soft key. You should see the SETTING (HANDY) screen. Change PARAMETER WRITE = to 1. You'll get an alarm, but you can ignore it.
    Then press SYSTEM function key, then [PARAM] soft key. Type in 100, then press [NO SRH] soft key. Cursor > to the bit you want to change. Key in 1 or 0 and press INPUT.
    7 6 5 4 3 2 1 0
    _ _ _ _ 1 0 _ _
    Now go back to the OFFSET/SETTING screen and change PARAMETER WRITE = to 0, reset the alarm and try outputting the program to the card.
    There's also a way to change the EOB output via the ALL IO screen, but I can't find the information on that.
    Good luck.
    Aug 2010
    188
    thanks again, hopefully i'm not being bothersome. you've helped me out on more than one occasion this week i think.
  1. Compact Flash Cards
    By dcoupar in forum Fanuc
    Last Post: 02-04-2010, 07:10 PM
  2. Compact Flash
    By jdgromi in forum French
    Last Post: 01-30-2010, 06:38 PM
  3. Run program from compact flash
    By fomaz in forum Fanuc
    Last Post: 10-20-2009, 08:27 PM
  4. Smooth Linear Motion in Compact Spaces with Low-Profile Redi-Rail®
    By Pacific Bearing in forum News Announcements
    Last Post: 09-22-2009, 10:44 PM
  5. Compact Flash to IDE/ATA adapter?
    By DennisCNC in forum Computers / Desktops / Networking
    Last Post: 11-05-2007, 05:27 AM
