586,094 active members*
4,034 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > CATIA Prismatic Machining question
    Apr 2008
    28
    I have a question regarding the 3-axis Machining aspect of CATIA V5, I am posting in both the CAD and CAM forums in hopes that someone can help me.
    I have figured out how to work the CAM functions and everything works except there is 1 issue. At the end of a tool path if I do not add in a tool change the cutter goes straight to the start of the next path, it does not pickup and move over. This is a problem because it cuts through the part instead of clearing it.
    How do I setup the system to do a vertical rapid to home or at least to a plane above the part so this does not happen?
    Stuff i can use: AutoCAD 2010, AutoCAD Inventor 2010, Solidworks 2009, MasterCAM X2/X4, CNC's FADAL, and Hurco 3-axis CNC Mill
    24
    Double click "part operation" to open part operatin window, there define safety plane ( note! you can define offset for safety plane by right click to plane after you have selected a plane)
    OR you can build your own approach and rectract moves in a last page in toolpath window called "Macro managment". Remember to activate macro you want to have.
    Mar 2008
    4
    HI, somebody helpme whith some tutorial on catia prismatic machining?
    thanks
  1. CATIA Prismatic Machining question
    By bigalexe in forum Uncategorised CAD Discussion
    Last Post: 12-25-2013, 06:56 PM
  2. prismatic machining/programming
    By shape in forum EdgeCam
    Last Post: 02-08-2009, 03:45 PM
  3. 4 Axis Machining in Catia
    By will1234 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-06-2009, 10:42 PM
  4. Pro Engineer-Prismatic Milling or Production Machining
    By Klaus in forum Uncategorised CAM Discussion
    Last Post: 07-23-2007, 09:38 AM
  5. Linear Rails vs Prismatic Ways
    By bcromwell in forum Uncategorised MetalWorking Machines
    Last Post: 03-25-2007, 08:35 PM
