586,096 active members*
3,727 visitors online*
Thread: X3 troubles
    Jan 2010
    294
    X3 troubles
    I was running my cnc'd X3 today and accidently hit the E-stop up by the motor. I went to reset the switch, and apparently the nut had backed off of the switch body, anyway, the switch pulled out enough that the terminals shorted on the case.
    It faults out now when I turn the spindle on. I checked the fuse but it was good ofcourse. I was too pissed off to do any further checking, I've already had to buy a replacement circuit board once when the motor control failed, and they weren't cheap. I just know I will have to buy another one.
    Has this happened to anyone else? Is there a chance something else failed that can be fixed without replacing the whole board?
    www.steelplinkers.com
    Mar 2007
    73
    Get in touch with John Gerling. He repairs DC controllers for asian minis. And he´s honest, he´ll tell you how to measure if it´s just a small bug or if more is wrong and if he can fix it. Great guy.
    http://www.mini-lathe.com/Controller...ir/Gerling.htm
    In case it is just the switch, you (or someone else familiar with high voltage) can bridge it for now. The emergency stop is just a solenoid/circuit breaker that connects or disconnects power to the drive board. Be careful, both the cables and the PCB of the DC drive are at line level.
    There should be a cable plan in the manual.
    Cheers,
    Johann
  1. MAX 100 troubles
    By matttargett4 in forum Hypertherm Plasma
    Last Post: 04-01-2010, 08:25 PM
  2. RPM troubles...
    By rylanrouge in forum MetalWork Discussion
    Last Post: 03-02-2010, 07:44 PM
  3. air troubles
    By wadetool in forum Haas Mills
    Last Post: 02-19-2007, 10:30 PM
  4. DXF troubles
    By kung in forum G-Code Programing
    Last Post: 11-02-2005, 10:41 PM
  5. CAD Troubles
    By Blackhawk in forum Uncategorised CAM Discussion
    Last Post: 06-12-2005, 04:13 AM
