586,115 active members*
3,554 visitors online*
    Jul 2010
    17
    Building my first CNC machine
    Hi all
    First off, i have no experience whit CNC machines, but i wanted one, and it is to expensive to buy, so i decided to make one... so if my design is poor, i apologise :P
    For a living i work as an automation technician so i understand how the machine moves and how the steppers, and controlboard works, so a little burden of my shoulders.
    The machine has some extra holes in it, cause i build it one way, and then changed the design after, so some unnecessary holes, there is
    -Basically the whole machine is made out of the sealink antenna by marlink, so if you study this picture, you will find alot of similarity's
    As i never tought on making a build thread, i havent taken many pictures while building, so the pictures i have now is of an almost complete cnc mill.
    But still some work to do, will be better whit the pictures
    (beacause of the large images, i have made click links)
    This is for my Z axe this is not complete yet.
    http://arandeb.com/kjetta/fresen/1.jpg
    This is the motor mount for the Z axe
    http://arandeb.com/kjetta/fresen/2.jpg
    This is how the Z axe moves
    http://arandeb.com/kjetta/fresen/3.jpg
    The ball bearings of the Z axe
    http://arandeb.com/kjetta/fresen/4.jpg
    All of the bearings of the Z axe
    http://arandeb.com/kjetta/fresen/5.jpg
    The Y axe, and a little of the X axis
    http://arandeb.com/kjetta/fresen/6.jpg
    How the X axis moves
    http://arandeb.com/kjetta/fresen/7.jpg
    The motor mount of the Y axis (the axle of the motor and the movment is a little off, but is now fixed
    http://arandeb.com/kjetta/fresen/8.jpg
    Motormount and mechanism of the X axe
    http://arandeb.com/kjetta/fresen/9.jpg
    The whole mill
    http://arandeb.com/kjetta/fresen/10.jpg
    This is what i have for now. I will come back whit more pictures as soon as i get them.
    As said before, i have no experience, so this mabe a poor design, but i do the best whit what i got
    Feb 2010
    14
    Nice work but I was wondering when I saw that u are belt driving the rails.
    Would it not have back lash problems. i have read abt it and that is why every one has the motor shaft direct coupled.
    Jun 2005
    176
    Like all machines I guess it will need a little tweaking but you have a pretty strong looking structure there and a basically sound machine. I like the plastic bed but how are you going to hold stuff in place while it's being cut?
    Jul 2010
    17
    No, i dont think the belts going to give me back lash, cause the I use ISO M8 bolt treads for moving the axes, so if i try to move any parts whitout the motors, it is impossible, the tread is to fine... It will take a long time to use the mill beacause of this, but it was what i had.
    Benonymous:
    I havent decided yet :P But the plan is eighter to cut square holes in it, and just make some cind of lock mechanism... But that will only be used on ingraving, the nylon plate was way to expensive to mill in :P So i am going to make some wood plates that fits ontop of the nylon, and just skrew whatever im milling tight to the wood.
    Sep 2005
    133
    Nice setup for your first build. My first couple of tries didn't look so hot, lots of revisions.
    http://www.homebrewedtechjunkie.com - My techie projects, including a cnc build.
  1. Why are you building your machine?
    By The J in forum DIY CNC Router Table Machines
    Last Post: 04-07-2009, 02:20 PM
  2. Building 2nd Machine
    By Paulds in forum CNC Wood Router Project Log
    Last Post: 03-17-2009, 10:08 PM
  3. When building a cnc machine??.........
    By axis_control in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2008, 03:02 PM
  4. I need help on building a CNC machine
    By loloy in forum Hobby Discussion
    Last Post: 05-15-2006, 01:11 PM
  5. When you done building your CNC machine
    By Todd Price in forum DIY CNC Router Table Machines
    Last Post: 04-22-2004, 05:14 AM
