587,043 active members*
3,269 visitors online*
    Feb 2005
    753
    running a bridge knee mill
    Is there anyway I can run it on a 110 outlet (house style). I want to get one to bridge some projects from school home.
    -garrett
    Dec 2003
    24223
    If it has a 240v 3ph spindle motor, then you can either build/buy a 3ph converter and run off 240 single phase or use a VFD on the spindle and run off 240 1ph.
    Al.
    Albert E.
    Feb 2005
    753
    oh yea and I can't do anything to the place cause it is an apartment....
    Dec 2003
    24223
    Quote Originally Posted by MBG
    I hope the floor can support it
    Actually you probabally have a 240v outlet for the stove
    Al.
    Albert E.
  1. Dyna Mechtronics cnc Knee Mill need help with control
    By wisp in forum Knee Vertical Mills
    Last Post: 01-08-2021, 05:20 PM
  2. Ancient Knee mill retrofit
    By kong in forum Knee Vertical Mills
    Last Post: 11-10-2007, 09:06 PM
  3. knee mill conversion
    By mtechserv in forum Knee Vertical Mills
    Last Post: 12-04-2004, 07:30 PM
  4. Knee Mill - Z Axis Options
    By Moondog in forum Knee Vertical Mills
    Last Post: 11-17-2004, 07:03 PM
  5. Prospects of CNC for grizzly knee mill
    By spunkrat in forum Uncategorised MetalWorking Machines
    Last Post: 06-04-2004, 05:17 AM
