Hello.
I need to produce several tools like the one in attachment (and other formats), normally all from carbide blanks.
What is the best way to produce this, so that the tool would be as perfect as possible? Or by your experience how would you grind it (machine, type of grinding disc, method...). A brief description, or any sugestion would be high appreciated.
I am willing to invest on a new process on my company.
For testing proposes, I have grinded it a green stone and then I finished with a diamond grinding disc on a manual tool grinding machine. The tool cuts, but I belive that there is a better method to produce this, especially because of low duration of the green grinding wheel and the heat produced.
Thank you
