586,076 active members*
3,843 visitors online*
Results 1 to 14 of 14
    Sep 2010
    8
    how to extrude
    Hello, need your help
    How can I extrude from one part a shape of another part, illustration attached. I need to extrude from Part 1 a shape of part 2,
    You suggestions much appreciated.
    Thank you, Gits
    Feb 2009
    2143
    If the shape from part 2 is all on one plane, the you should be able to select that edge, then use the Extrude command, and go from surface (choose part 1 face) and go either a blind distance or to the face of part 2.
    If that does not work, you may need to create a plane and then use the command "convert entities" to create a new sketch of the "pieces" of part 2 that you want to extrude. The use this new sketch to extrude the feature.
    Or one of several other methods...
    Sep 2010
    8
    Quote Originally Posted by mcphill View Post
    Got it, thank you. I was hoping I can just use 3D part 2 to extrude
    from part 1 in one go, without getting involved in sketching (kind of
    logical) - but it could be naive perception of the beginner
    Jun 2010
    This will most likely cause you more problems due to all the weird trimming that you have to do. Your part looks simple and if it won't be going into some detailed assembly it will work
    Start out by trimming and filling in the knob to look like this.
    Then you can shell the part to the outside. This would have worked better if I trimmed the radius on the unimportant side of the knob. None the less this made the part opposite of what it was with enough material to make your other part by trimming material.
    Trimmed
    I don't know exactly what you are trying to do but you should be able the shell your way to your final part.
    Travis
    Sep 2010
    8
    That is it! Thank you Travis
    Dec 2008
    4548
    Isnt this just a simple Boolean cut???
    Dec 2008
    4548
    Insert-features-indent...Use the cut tick mark in the command.
    Jun 2010
    You'll have to explain more burrman. I only do it this way because I don't no any better. It sounds like using a boolean cut would be easier but I have never used it in SW. Please continue!
    Travis
    Jun 2010
    I found a youtube video explaining it. Your correct that is much easier, But in 2010 it is using the combine feature and subtracting the material from one part from the other.
    Type "how to boolean cut in solidworks" on youtube there is a good tutorial on it
    Thank you Burrman
    Travis
    Dec 2008
    4548
    Yeah, you can find most stuff there.. Using "Indent" has some advantages also....Check this site out for some info:
    http://www.solidworker.com/171/boole...n-with-indent/
    He will explain some advantages of the indent to do a boolean cut...
    Sep 2010
    8
    Quote Originally Posted by BurrMan View Post
    Thank you - boolean cut worked well
    Mar 2006
    489
    I would use a derived sketch of the original geometry, that way it will stay linked.
    Check out derived sketches in help.
    Paul
    Jun 2010
    Quote Originally Posted by fatal-exception View Post
    FYI
    After using the indent feature I changed the some dimensions on the knob and the negative changed with it.
    Sep 2005
    1660
    my preference over indent would be to use 'combine' w/ the subtract button clicked..
    JerryFlyGuy
    The more I know... the more I realize I don't
  1. Extrude a cut?
    By phil m in forum Rhino 3D
    Last Post: 12-23-2013, 11:25 AM
  2. Extrude hone Media
    By bl409 in forum Mass finishing equipment/media/strategies
    Last Post: 11-02-2011, 09:03 PM
  3. Unigraphics Extrude / sketcher
    By greenchair in forum Uncategorised CAD Discussion
    Last Post: 01-05-2009, 04:10 PM
  4. Unable to extrude along path
    By PeteGallo in forum Autodesk
    Last Post: 03-15-2008, 08:16 PM
  5. SW 2007 Extrude and chafer?
    By john_t_h in forum Solidworks
    Last Post: 03-11-2008, 12:20 PM
