586,103 active members*
3,612 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > UK Supplier of low cost Quality CNC machines
    Sep 2010
    14
    300mm x 200mm CNC machine - £749.99
    400 x 300mm CNC machine - £849.99
    contact [email protected] for more details.
    Model: BC400300 desktop CNC engraver / router
    Axis: 3 axis
    Dimensions 550x400x350mm
    Working area 400x300x60mm (x,y,z)
    Max work piece thickness <=70mm
    Work Table Size 450x340mm
    Material Composition Aluminium Alloy
    Sliding Unit X-axis=13mm round rail, Y-axis=16mm round rail , Z-axis=12mm round rail
    Transmission Unit: Special high precision 1204 double spin trapezoidal screws
    Stepper Motor: 3 x 57 series 2phase,1.5A new stepper motors
    Accuracy 0.08mm
    Resetting Accuracy 0.03mm
    Spindle 300W low noise 'refurbished' Professional model
    Spindle Speed 5000-9500 rpm
    Max Speed 4000mm/min
    Max Engraving Speed 2000mm/min
    Weight 34Kg
    Voltage 220V
    Accessories
    • 1 X,Y,Z control box, easy connection with spindle speed adjustment, spindle and drive on/off buttons
    • Cable feed system
    • 1 x parallel cable
    • 5 x engraving / milling bits
    • 1 x collet wrench
    Jul 2010
    25
    Is that the 3040 router from CNCDIY? What's it like?
    Sep 2010
    14
    3040
    No. They are different but look similar, I had a couple of machines from them and it was a mistake. The build quality was rubbish, packaging was even worse which resulted in damaged machine beds and the controllers did not work properly, I had to send the controllers back at my cost and when the 'new' ones arrived they were faulty too. Also the back of the controller was not cut properly so the 'ports' did not fit and it was virtually impossible to put the leads in. The leads were not enclosed and able to be screwed on as mine are and when all come to all, they eventually admitted that they use 'used' parts for the contollers as well so I abandoned that route.
    I approached a reliable company I know to build my design at my spec and that is what is for sale now. Good quality machines at a low cost!
    Jul 2010
    25
    Ok. Can you please tell me (or PM) me a price and some details for a 40x30 setup with larger stepper motors and a more powerful router (eg 1.2-1.5kw). Do you recommend air or water-cooled? And 2 collets that can take 2.0mm - 1/2" cutters. I am in Australia so an idea of shipping cost to postcode 3766 would be great. Thx
  1. LOW COST BEST QUALITY LARGE RELIEF MODELS
    By Khalid in forum ArtCam Pro
    Last Post: 07-25-2012, 10:30 AM
  2. Supply cost effective high quality PCB&PCBA
    By fanjing322 in forum News Announcements
    Last Post: 05-31-2010, 09:31 AM
  3. Want to buy low cost laser machines
    By dynamic-laser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-01-2009, 05:14 PM
  4. Brand New High Quality - Low Cost Nested Base CNC Routing Solution
    By Kookaburra in forum News Announcements
    Last Post: 09-22-2009, 08:06 AM
