586,068 active members*
3,693 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > What's your favorite JGRO upgrade?
Page 1 of 2 12
Results 1 to 20 of 28
    Sep 2004
    85
    OK, so I'd like to have folks post their favorite improvements and upgrades to the JGRO router design. I am weighing the cost/benefits of building a brand new (larger, faster) machine similar to a Joe's Hybrid (except more like a 2'x4') or just upgrading my existing JGRO router. Ideally, I'd build a new machine, but as I start to add up the costs, I'm thinking I may need a "plan B" to keep the "finance comittee" happy.
    Here's what I have to work with currently:
    - JGRO router build mostly to specs
    - Hobby CNC Pro 4-axis driver board
    - Hobby CNC 130 oz stepper motors
    - 24V power supply
    - Burnt out Dremel "spindle" (failed the last time I used it)
    I've considered purchasing a set of 205 oz steppers to add some beef, especially if I was to build a new machine...
    For fabrication capabilities, I can handle all the usual hobby CNC things, including welding (I typically prefer metal fab over woodworking). I also have a backyard aluminum foundry to help with odd-shaped parts.
    Please post upgrades you've done/seen and liked. It can be links to other threads/posts or a pic of some small tweak you might have made to your JGRO along the way. Anything that'll increase the speed/accuracy/stiffness/etc of the machine as a "Plan B" vs building a brand new router.
    Thanks!
    Jul 2006
    77
    I've just finished my machine.. I've got the Hobby CNC 4Axis Pro kit with the 305 oz motors.. I'm quite happy with that..
    I can already tell though, my first upgrade for this machine is going to be doing away with the 1/4 20 all thread and get some faster screws. As far as spindle goes.. look at the Bosch Colt palm router. I'm quite pleased with it..
    Sep 2004
    85
    Glad to hear that you're happy with the Bosch Colt. I've been eyeing it as a possible spindle for a while (like the variable speed that adjusts to load), especially for the JGRO sized machine. If I went larger with an all-new (and maybe all-metal) router, I'd be tempted to go with a full-size router for the 1/2" capability...
    I would agree with the 1/4-20 screws being painfully slow. For a JGRO upgrade, I've thought about 1/2-8 2-start (1/4" lead) which should let me move at 100 IPM even with my 130 oz steppers (can go 20 IPM with the 1/4-20 screws) Most of my machining is foam for casting patterns and some MDF or oak. Of course, with an upgraded or new machine, I'll be very tempted to start diving into a chunk of aluminum plate or something...
    Apr 2009
    144
    1/2" acme and HDPE adjustment blocks.
    Some Y rail support would be nice as well, but I haven't got there yet.
    JGRO Complete - G540, 380oz Nema23s, 1/2-10 ACME, 30"x14", Craftsman router
    Joes 4x4 R&P in progress
    Sep 2004
    85
    Yeah, still thinking about supports for the Y rails... Haven't come up with anything real clever yet.
    Forgot to mention in the original post, but I've already got the adjustment blocks covered. After splitting out the first MDF one, I jumped straight to casting aluminum blocks for all of the axis. The blocks are stout, just need to stiffen up those Y-rails...
    Has anyone done a dual leadscrew on the Y axis for one of these machines? Or rearranged the Y-axis bearings to increase the width/tightness?
    Oct 2009
    254
    Instead of Y supports, why not just go to a solid 20mm linear shaft? Can get them cheap enough off ebay and other sources. Just a thought..
    Dec 2006
    177
    Here are my X axis supports, these are fashioned after what Jason Marsha did on his build a few years ago.
    I am running 5/8" - 11 all-thread for all three axis. Each lead screw is kind of pretensioned as each end has a bearing and a nut retaining the screw from moving forward and aft; then the stepper motor is mounted to the mdf standoff, the 1/4" stepper shaft and the 5/8" all-thread are joined by Lovejoy couplers.
    I have also changed the base and table layout some to use angle iron for the table, making it much simpler for myself.
    Tom
    Oct 2005
    1237
    I did a lot of reading before i started my JGRO. Before building the base I drilled pass holes for the Y (X?) axis supports and used 1/4-20 all thread as the cross ties. Make sure to run nuts down to the base so the all thread is stiff and doesn't bounce back and forth through the base.
    1/2-10 ACME, but think I'd rather have gone with two start than single.
    DUST BOOT! Lord what a mess. It for sure needs a dust boot.
    285ozin X and Y with a 425ozin Z. G540 with 48v PS
    PAINT If it isn't industrial gray, it isn't a true machine.
    I need better shaft supports yet, and better motor mounts. Even so, I can get it to rapid as fast as 180 IPM. Due to the crappy motor mounts bought, it still isn't spot on though.
    Oct 2009
    254
    again this goes back to my question above, why not just go with solid shafts instead of gas pipe? Can get these pretty cheap. Wouldn't need to do anything with supports then.
    http://cgi.ebay.com/20mm-CNC-Router-...item5d249e27d4
    Feb 2010
    55
    You will still need support. Just because they are solid does not mean they wont flex.
    For a straight out of the box solution use these: http://cgi.ebay.com/Linear-CNC-Route...item19b228db8c - You will need the correct length for your machine though..
    But, they are expensive.
    Oct 2009
    254
    Thanks for pointing that out. Being that they are solid, I just assumed they were too tough to flex. I'm still planning my build so it's good to know all this beforehand. I can see that's why most people go with gas pipe, especially if you have to support it anyway.
    Ya, I've seen those supported shafts before on ebay, very expensive. That price is just for one.
    Apr 2009
    144
    I've kinda had my eye on these as a MUCH cheaper alternative to the one piece supported rod and vxb bearings/blocks
    http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en
    Sep 2004
    85
    Well, so far, my "Plan B" is looking to be something like:
    Stage 1: Increase Speed and tigthen up Y rails
    - Replace lead screws with 1/2-8 2-start ACME w/ new AB nuts from Dumpster or other
    - Add Y-rail supports to retain pipe rails on the outside and vertically, at least somewhat. (I have a design in my head, but haven't had a chance to draw it up yet)
    - Repair or replace Dremel spindle (start with new brushes for the Dremel, move on to cheap trim router if Dremel is indeed dead)
    Stage 2: Add strength:
    - Using the faster machine from above, start rebuilding a new gantry out of aluminum castings to replace the MDF gantry that likes to flex (Al is roughly 17 times stiffer than MDF, so even a relatively small cross-section Al part can beat the MDFpieces for deflection, Plus, Al won't have the humidity/moisture concerns to deal with) In building the new gantry, I think I'll eliminate the Y axis bearing support blocks (that space the angle iron/aluminum out away from the side of the gantry) and mount the bearing angles direct to the side plates, which'll increase the X-axis travel by 1.5" up to 17". Not the 24" I hoped for, but a little more room never hurts.
    - Also using Al castings, rebuild the Z carriage, even though it's pretty rigid as-is. Might rebuild to increase under-gantry clearance in combination with a little taller gantry or slightly compressed X rail spacing or something...
    Stage 3: More power
    - Swap out the Dremel or cheapo trim router with a variable speed router (either a Bosch Colt or go up to a full-size model).
    - Upgrade to larger steppers
    Not sure any of the 20mm or similar supported rail setups are in the budget once I would buy lead screws and such for "stage 1" About the only way I'll pull off an aluminum gantry is using homemade castings made from old lawnmower engines and other scrap material...
    Sep 2004
    85
    A question though on the lead screws... Anyone using 1/2-10 5-start (0.5" lead" ACME screws with the 205 oz Hobby CNC steppers? One thought I'd had was that the Y-axis screw could someday be reused as the X-axis on a 2'x4' machine, so if they'd work with the currrent setup, I could maybe plan ahead a little for "Plan A" just in case that ever happens.
    Sep 2009
    84
    Ours is 90% complete now, however so far swapping out components for rack and pinion is my fav. We are getting 750ipm feed moves in our relativly short 15" of Y travel. Our X travel should be around 92", cant wait to see that moving.
    Im also swapping out the pipe guide's for something similar to cncparts leaner bearing setup using a 1/4x3 1018 plate for a bearing guide, that should take away alot of rolling resistance, it can only get faster
    Dec 2006
    177
    Quote Originally Posted by Rotax91 View Post
    Actually for this size of material the pipe will be stronger(less flex) than the solid. And yes you will still need to support them.
    Tom
    Aug 2008
    50
    According to Ger21 a multiple start lead screw is more accurate than a single start, so I went with 1/2 8-2 Acme and I like it. I'm slowly putting together a Gecko 540 and accompanying box, right now I use xylotex. If I can load the picture of my long axis (X) support, I will. [IMG]72649[/IMG]
    Great machine, great thread.
    Tom
    Aug 2008
    50
    Sorry, The picture of the support did not upload, I'll try again later.
    Tom
    Aug 2008
    50
    OK I'm going to try again with the picture.
    Aug 2009
    To anyone who replaced the threaded rod with a 2 or 5 start 1/2" acme - do you mind sharing how your z axis is now supported? Seems like the same nuts on the salve end per the plans would no longer be viable. I have the lovejoy couplers with 5 start 1/2" acme rod, but I am wondering how to support the weight of the z axis - does this make sense? Maybe the coupler will be enough, but it looks like the plans have the z axis load supported with both a coupler and with the z axis bearing. This is probably not the right place for this post, but thought I would exploit the fact that people with modified designs are likely in this thread anyway!
Page 1 of 2 12
  1. Favorite Swiss cutting oil??
    By PoiToi in forum CNC Swiss Screw Machines
    Last Post: 01-25-2019, 10:01 PM
  2. Favorite Mods
    By doanwannapickle in forum Taig Mills / Lathes
    Last Post: 09-13-2009, 11:09 PM
  3. Favorite G offset?
    By Trapper14 in forum G-Code Programing
    Last Post: 08-14-2006, 03:02 PM
  4. Favorite Camsoft trick
    By Karl_T in forum CamSoft Products
    Last Post: 08-07-2006, 08:24 PM
  5. What is you favorite printer?
    By cncadmin in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 09-25-2005, 03:21 AM
