586,094 active members*
4,052 visitors online*
Thread: srv400 board
    Dec 2007
    159
    srv400 board
    I have 2 -3 axis H20T43-SRV400 boards.Is it possible to make the 4 axis board with the electronics I have on hand?
    May 2009
    281
    yes and no. you have isa cards which should work, on the card there are 3 large ic chips and one empty socket all you need is one more chip and you can controle one more axis, if you have another amplifier card to power the servo. as well as the aditional motor cables etc.
    if you have a chip puller you can remove one chip from one board and add it to the other. watch out for static and bent pins.
  1. Replies: 1
    Last Post: 06-01-2010, 05:31 AM
  2. I only need the board
    By homsar66 in forum Xylotex
    Last Post: 02-11-2010, 08:34 PM
  3. How to connect ELM Board and OSMC Board ?
    By bigeye3107 in forum Open Source Controller Boards
    Last Post: 06-16-2008, 12:26 PM
  4. Breakout board, Relays on board?
    By Cooper in forum Open Source Controller Boards
    Last Post: 06-10-2007, 01:55 AM
  5. Replies: 7
    Last Post: 02-10-2007, 04:45 AM
