i cannot for the life of me get bob-cad to simulate my parts, nor will predator editor. any help would be appreciated.
(go easy on me i'm new to this and self taught)
There is so much information there, I almost dont know where to start!!!!
Generate a toolpath and then right clcik and choose "Verify!"
i realize my question was short of info but i didn't want to go off babbling about something i know nothing about and spew out a bunch of useless info.
what types of things would you like to know in order to help me solve this problem?
i have tried to right click and select verify, the software says "no data to verify" when i have clearly out put a working program.
same thing in predator editor
Can you walk through a simple circle pocket??? Draw a circle, select pocket...Generate toolapth....etc...
No data to verify - Is that a path issue for Predator?
In BobCAD, go to Preferences - Settings Default
In the popup window click the "Directories" tab.
For "Project", click the ellipses (...) and navigate to this folder:
C:\Program Files (x86)\Predator Software\Common Files\Jobs
or
C:\Program Files\Predator Software\Common Files\Jobs
See if that doesn't fix it. Sorry, that's all I got.
@Burrman
are you asking me to do it? or are you asking me if i am able to do it?
if what you are asking me is, can i do it the answer is yes. i have been using bob-cad to create programs for a few weeks now, programs work, parts are good.
the only problem i am having is simulating them. i have been creating programs and running them on a simulator on a okuma controller in the shop. they work but it is just kind of a hassle.
@SBC cycle
thanks for the reply! i tried this and the directory you gave me was already
defaulted to. i reselected to be sure but it didn't help.
Hello Jay... Just asking you to walk through simple steps so we have a starting point...Better yet, make a file with a circle toolpathed and zip it and post it here...
If you get "No data to verify" error, the default project path doesn't exist. If no error but only empty window comes up, Predator software is not installed. There are two Preditor installs in:
C:\Program Files\BobCAD-CAM\BobCAD-CAM V23\System Files
They'd install both the simulator and editor, which should enable the "Verify" and "Edit" menus.
hopefully this helps....
Hey dizzle,
The bbcd file (Or BobCad file....) This will have your geometry and toolpath selection and such, with some other info that may help...
MAYBE THIS? I KNOW ITS NOT EXACTLY WHAT YOUR ASKING FOR BUT I'M REALLY BUSY IN THE SHOP RIGHT NOW AND DON'T HAVE THE TIME TO SPARE CREATING NEW FILES FOR THIS. IT IS JUST A "DRILL CYCLE" (A LIED TO CENTER DRILL CYCLE) AND A ROUGHING/FINISHING PROFILE PASS.
****** Computer System *****
Manufacturer : Hewlett-Packard
Model : HP Z800 Workstation
SystemType : x64-based PC
Description : AT/AT COMPATIBLE
NumberOfProcessors : 2
NumberOfLogicalProcessors : 12
TotalPhysicalMemory : 51522015232
BootupState : Normal boot
DNSHostName : user-HP
Domain : decanet.internal
PrimaryOwnerName : user
UserName : DECANET\cadoperator
***** Sysyem CPU Info *****
Manufacturer : GenuineIntel
DeviceID : CPU0
ProcessorId : BFEBFBFF000206C2
Description : Intel64 Family 6 Model 44 Stepping 2
Name : Intel(R) Xeon(R) CPU X5670 @ 2.93GHz
NumberOfCores : 6
NumberOfLogicalProcessors : 6
MaxClockSpeed : 2.927 MHz
DeviceID : CPU1
NumberOfCores : 6
***** System Graphics *****
AdapterDACType : Internal DAC(400MHz)
Description : ATI FirePro V5700 (FireGL)
DeviceID : VideoController1
DriverVersion : 8.701.1.0
InfFilename : oem37.inf
InfSection : ati2mtag_R7XGL
InstalledDisplayDrivers : atiu9p64.dll,aticfx64.dll,atiu9pag,aticfx32,atiumd 64.dll,atidxx64.dll,atiumdag,atidxx32,atiumdva,ati umd6a.cap,atitmm64.dll
Name : ATI FirePro V5700 (FireGL)
VideoModeDescription : 2560 x 1600 x 4294967296 colors
VideoProcessor : ATI display adapter (0x949E)
AdapterCompatibility : ATI Technologies Inc.
AdapterRAM : 512.000 MB
CurrentHorizontalResolution : 2560
CurrentVerticalResolution : 1600
CurrentNumberOfColors : 4294967296
CurrentRefreshRate : 59
DriverDate : 20100225000000.000000-000
***** System OS *****
Manufacturer : Microsoft Corporation
Caption : Microsoft Windows 7 Professional
BuildNumber : 7600
Version : 6.1.7600
BuildType : Multiprocessor Free
CodeSet : 1252
CountryCode : 2
CSName : USER-HP
Locale : 1009
Organization : Hewlett-Packard Company
OSArchitecture : 64-bit
EncryptionLevel : 256
FreePhysicalMemory : 46491548
FreeSpaceInPagingFiles : 50314468
FreeVirtualMemory : 96524456
InstallDate : 20100608081831.000000-360
LastBootUpTime : 20100913113016.095997-360
MaxProcessMemorySize : 8589934464
NumberOfProcesses : 49
ServicePackMajorVersion : 0
ServicePackMinorVersion : 0
BootDevice : \Device\HarddiskVolume1
SystemDevice : \Device\HarddiskVolume2
SystemDirectory : C:\Windows\system32
SystemDrive : C:
TotalVirtualMemorySize : 100627036
TotalVisibleMemorySize : 50314468
WindowsDirectory : C:\Windows
Description : Local Fixed Disk
DeviceID : C:
FileSystem : NTFS
FreeSpace : 192101646336
VolumeName : OS
VolumeSerialNumber : 5E0253E1
Compressed : False
Description : CD-ROM Disc
DeviceID : D:
Description : Removable Disk
DeviceID : E:
DeviceID : F:
DeviceID : G:
DeviceID : H:
Description : Network Connection
DeviceID : L:
FileSystem : NTFS
FreeSpace : 606646812672
ProviderName : \\deca-dc1\users$\cadoperator
VolumeName : Data Volume
VolumeSerialNumber : D0681953
Compressed : False
DeviceID : X:
FileSystem : NTFS
ProviderName : \\deca-dc1\shop
Compressed : False
DeviceID : Y:
FileSystem : NTFS
ProviderName : \\deca-dc1\cad operator
Compressed : False
DeviceID : Z:
FileSystem : NTFS
ProviderName : \\deca-dc1\drawings
Compressed : False
Hi Burr
Yes, it Verified and Backplotted in Predator fine here also so can`t see anything wrong with his files.
Here is a daft suggestion, I know the directory path was checked and appeared to be OK but is Predator actually installed at that location ???
May need a new download and install of Predator ??? Not from inside BobCAD !!
http://www.bobcadsupport.com/tech/in...adsupport/tech
Clutching at straws
Regards
Rob
:rainfro::rainfro::rainfro:
He did say he checked the directory path, but eluded to it being set as the default that sbc posted. But sbc posted 2 paths and since he has a 64 bit os, his path should be the one with the (x86) in the program files part...
Is this the path there...?????
Also, as Rob points out, the best way to be sure is to actually "Browse" to each folder that is listed...That way you can be sure the path is correct...
my path was indeed the one with the (x86). i'll try to browse to it when i get a chance today and let you know how that goes
