586,116 active members*
3,440 visitors online*
Page 1 of 2 12
Results 1 to 20 of 31
    Aug 2010
    188
    Thumbs up cannot simulate!
    i cannot for the life of me get bob-cad to simulate my parts, nor will predator editor. any help would be appreciated.
    (go easy on me i'm new to this and self taught)
    Dec 2008
    4548
    There is so much information there, I almost dont know where to start!!!!
    Generate a toolpath and then right clcik and choose "Verify!"
    Aug 2010
    188
    i realize my question was short of info but i didn't want to go off babbling about something i know nothing about and spew out a bunch of useless info.
    what types of things would you like to know in order to help me solve this problem?
    i have tried to right click and select verify, the software says "no data to verify" when i have clearly out put a working program.
    same thing in predator editor
    Dec 2008
    4548
    Can you walk through a simple circle pocket??? Draw a circle, select pocket...Generate toolapth....etc...
    Apr 2008
    1577
    No data to verify - Is that a path issue for Predator?
    In BobCAD, go to Preferences - Settings Default
    In the popup window click the "Directories" tab.
    For "Project", click the ellipses (...) and navigate to this folder:
    C:\Program Files (x86)\Predator Software\Common Files\Jobs
    or
    C:\Program Files\Predator Software\Common Files\Jobs
    See if that doesn't fix it. Sorry, that's all I got.
    Aug 2010
    188
    @Burrman
    are you asking me to do it? or are you asking me if i am able to do it?
    if what you are asking me is, can i do it the answer is yes. i have been using bob-cad to create programs for a few weeks now, programs work, parts are good.
    the only problem i am having is simulating them. i have been creating programs and running them on a simulator on a okuma controller in the shop. they work but it is just kind of a hassle.
    Aug 2010
    188
    @SBC cycle
    thanks for the reply! i tried this and the directory you gave me was already
    defaulted to. i reselected to be sure but it didn't help.
    Dec 2008
    4548
    Hello Jay... Just asking you to walk through simple steps so we have a starting point...Better yet, make a file with a circle toolpathed and zip it and post it here...
    Sep 2010
    If you get "No data to verify" error, the default project path doesn't exist. If no error but only empty window comes up, Predator software is not installed. There are two Preditor installs in:
    C:\Program Files\BobCAD-CAM\BobCAD-CAM V23\System Files
    They'd install both the simulator and editor, which should enable the "Verify" and "Edit" menus.
    Aug 2010
    188
    Quote Originally Posted by Kenji View Post
    I have checked the project path and it is correct. also predator software has been installed, "verify" and "edit" options are available. the "edit" option works just fine, the "verify" option does not.
    Aug 2010
    188
    Quote Originally Posted by BurrMan View Post
    ok now your gonna laugh at me for sure, how do i "zip" a file???
    you can stop laughing now........
    Aug 2010
    188
    HERE GOES NOTHING
    hopefully this helps....
    Attached Files Attached Files
    Dec 2008
    4548
    Hey dizzle,
    The bbcd file (Or BobCad file....) This will have your geometry and toolpath selection and such, with some other info that may help...
    Dec 2008
    4548
    The other thing I'll need to see is the post processor you are using... The code you posted is incomplete for using backplot, but the built in verify should work on the bbcd file.
    DOes this look like your program you posted?
    Aug 2010
    188
    MAYBE THIS? I KNOW ITS NOT EXACTLY WHAT YOUR ASKING FOR BUT I'M REALLY BUSY IN THE SHOP RIGHT NOW AND DON'T HAVE THE TIME TO SPARE CREATING NEW FILES FOR THIS. IT IS JUST A "DRILL CYCLE" (A LIED TO CENTER DRILL CYCLE) AND A ROUGHING/FINISHING PROFILE PASS.
    Dec 2008
    4548
    Well that part verify's over here, so be sure to let me know when your ready to try a couple things...
    First thing you can do is to go to the BobCad help menu, and select System Info, then clcik the copy to clipboard button, then reply here and hit Ctrl+V.
    Aug 2010
    188
    ****** Computer System *****
    Manufacturer : Hewlett-Packard
    Model : HP Z800 Workstation
    SystemType : x64-based PC
    Description : AT/AT COMPATIBLE
    NumberOfProcessors : 2
    NumberOfLogicalProcessors : 12
    TotalPhysicalMemory : 51522015232
    BootupState : Normal boot
    DNSHostName : user-HP
    Domain : decanet.internal
    PrimaryOwnerName : user
    UserName : DECANET\cadoperator
    ***** Sysyem CPU Info *****
    Manufacturer : GenuineIntel
    DeviceID : CPU0
    ProcessorId : BFEBFBFF000206C2
    Description : Intel64 Family 6 Model 44 Stepping 2
    Name : Intel(R) Xeon(R) CPU X5670 @ 2.93GHz
    NumberOfCores : 6
    NumberOfLogicalProcessors : 6
    MaxClockSpeed : 2.927 MHz
    DeviceID : CPU1
    NumberOfCores : 6
    ***** System Graphics *****
    AdapterDACType : Internal DAC(400MHz)
    Description : ATI FirePro V5700 (FireGL)
    DeviceID : VideoController1
    DriverVersion : 8.701.1.0
    InfFilename : oem37.inf
    InfSection : ati2mtag_R7XGL
    InstalledDisplayDrivers : atiu9p64.dll,aticfx64.dll,atiu9pag,aticfx32,atiumd 64.dll,atidxx64.dll,atiumdag,atidxx32,atiumdva,ati umd6a.cap,atitmm64.dll
    Name : ATI FirePro V5700 (FireGL)
    VideoModeDescription : 2560 x 1600 x 4294967296 colors
    VideoProcessor : ATI display adapter (0x949E)
    AdapterCompatibility : ATI Technologies Inc.
    AdapterRAM : 512.000 MB
    CurrentHorizontalResolution : 2560
    CurrentVerticalResolution : 1600
    CurrentNumberOfColors : 4294967296
    CurrentRefreshRate : 59
    DriverDate : 20100225000000.000000-000
    ***** System OS *****
    Manufacturer : Microsoft Corporation
    Caption : Microsoft Windows 7 Professional
    BuildNumber : 7600
    Version : 6.1.7600
    BuildType : Multiprocessor Free
    CodeSet : 1252
    CountryCode : 2
    CSName : USER-HP
    Locale : 1009
    Organization : Hewlett-Packard Company
    OSArchitecture : 64-bit
    EncryptionLevel : 256
    FreePhysicalMemory : 46491548
    FreeSpaceInPagingFiles : 50314468
    FreeVirtualMemory : 96524456
    InstallDate : 20100608081831.000000-360
    LastBootUpTime : 20100913113016.095997-360
    MaxProcessMemorySize : 8589934464
    NumberOfProcesses : 49
    ServicePackMajorVersion : 0
    ServicePackMinorVersion : 0
    BootDevice : \Device\HarddiskVolume1
    SystemDevice : \Device\HarddiskVolume2
    SystemDirectory : C:\Windows\system32
    SystemDrive : C:
    TotalVirtualMemorySize : 100627036
    TotalVisibleMemorySize : 50314468
    WindowsDirectory : C:\Windows
    Description : Local Fixed Disk
    DeviceID : C:
    FileSystem : NTFS
    FreeSpace : 192101646336
    VolumeName : OS
    VolumeSerialNumber : 5E0253E1
    Compressed : False
    Description : CD-ROM Disc
    DeviceID : D:
    Description : Removable Disk
    DeviceID : E:
    DeviceID : F:
    DeviceID : G:
    DeviceID : H:
    Description : Network Connection
    DeviceID : L:
    FileSystem : NTFS
    FreeSpace : 606646812672
    ProviderName : \\deca-dc1\users$\cadoperator
    VolumeName : Data Volume
    VolumeSerialNumber : D0681953
    Compressed : False
    DeviceID : X:
    FileSystem : NTFS
    ProviderName : \\deca-dc1\shop
    Compressed : False
    DeviceID : Y:
    FileSystem : NTFS
    ProviderName : \\deca-dc1\cad operator
    Compressed : False
    DeviceID : Z:
    FileSystem : NTFS
    ProviderName : \\deca-dc1\drawings
    Compressed : False
    Jun 2008
    1838
    Hi Burr
    Yes, it Verified and Backplotted in Predator fine here also so can`t see anything wrong with his files.
    Here is a daft suggestion, I know the directory path was checked and appeared to be OK but is Predator actually installed at that location ???
    May need a new download and install of Predator ??? Not from inside BobCAD !!
    http://www.bobcadsupport.com/tech/in...adsupport/tech
    Clutching at straws
    Regards
    Rob
    :rainfro::rainfro::rainfro:
    Dec 2008
    4548
    He did say he checked the directory path, but eluded to it being set as the default that sbc posted. But sbc posted 2 paths and since he has a 64 bit os, his path should be the one with the (x86) in the program files part...
    Is this the path there...?????
    Also, as Rob points out, the best way to be sure is to actually "Browse" to each folder that is listed...That way you can be sure the path is correct...
    Aug 2010
    188
    my path was indeed the one with the (x86). i'll try to browse to it when i get a chance today and let you know how that goes
Page 1 of 2 12
  1. simulate Mill/turn ISO?
    By CNCRim in forum NCPlot G-Code editor / backplotter
    Last Post: 01-08-2012, 11:43 AM
  2. How do you simulate with welded beams?
    By bigalexe in forum Solidworks
    Last Post: 08-10-2010, 11:08 AM
  3. Simulate does not work...
    By Big John T in forum BobCad-Cam
    Last Post: 03-06-2007, 11:07 PM
  4. Simulate help
    By Dfennell in forum BobCad-Cam
    Last Post: 01-27-2007, 06:18 AM
  5. Peck Cycles and Simulate
    By bill south in forum BobCad-Cam
    Last Post: 12-26-2006, 12:06 AM
