586,321 active members*
3,817 visitors online*
    Sep 2010
    1999 VF3 HAAS Alarm# 175
    I have a 1999 VF3 Haas 20HP vector drive vertical mill. Was homing out XYZ. Shuttle in then went into alarm #175 ground fault detected. I burned out R3 6.8 ohm 20 watt resistor on the IO PCB board. Has anyone else had this problem, if so, how have you corrected this issue. HELP.
    Aug 2010
    579
    There is most likely a short that needs to be located before the board is replaced. Based on the pre-condition description provided, I suggest checking the tool changer motors.
  1. haas vf-0 alarm 160
    By turboboy in forum Haas Mills
    Last Post: 07-06-2022, 08:40 PM
  2. ALARM shuttle drawbar alarm haas
    By timmydabull in forum Haas Mills
    Last Post: 02-18-2013, 07:47 PM
  3. Alarm 157 Haas VF3-SS
    By rshields21 in forum Haas Mills
    Last Post: 12-09-2011, 09:03 AM
  4. haas 160 alarm
    By s00073055 in forum Haas Mills
    Last Post: 10-22-2009, 06:19 PM
  5. haas 117 alarm
    By performancerhin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-21-2009, 06:03 PM
