586,119 active members*
3,583 visitors online*
Thread: Hoss's G0704
Page 102 of 344 25292100101102103104112152202
Results 2,021 to 2,040 of 6871
  1. #2021
    Thanks fellas!
    Made the nema 34 mount and set it up today.
    Didn't have the locks on and the 5th didn't cause any vibration at all, was only using a 3/16 endmill though.
    Snugged the worm up as tight as I dare to get the backlash down as best as possible, will check it tomorrow.
    Tried the nema 34 first in parallel then series mode.
    Ran the same speed in parallel as the 570's best (it's harder to rotate now though)
    Got a 20% speed improvement in series mode.
    Will try a lower pulley ratio again, running 1:1 now.
    The tool would be seeing something along the lines of 150 IPM right now.
    Hoss
    Attached Thumbnails Attached Thumbnails 092911 018_800x600.jpg   092911 020_800x600.jpg
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #2022
    OK, the 5th axis is done, mechanically.
    This nema 34 at 1.6:1 and bipolar parallel gives the best results.
    It's moving 77% faster than the 570 n23.
    Backlash is down to .012 degree, about .001 as the tool would see.
    The tool would move at about 190 IPM.
    Hogged some ally with the locks off and it runs very solid.
    Have a belt cover to draw up and machine out of plastic then to learn the software.
    Technically need to get the 4th axis rotary running again to make a part with 5 axis'
    but in due time.
    Hoss
    [ame=http://www.youtube.com/watch?v=zEaGx6an4es]G0704 5th Axis Final Setup and Hogging. - YouTube[/ame]
    Attached Thumbnails Attached Thumbnails 093011 006_800x600.jpg   093011 009_800x600.jpg
  3. #2023
    Dec 2007
    2134
    Fantastic stuff Hoss! It's so inspirational the stuff you do. Makes it seem like us mere mortals could achieve it
    cheers,
    Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  4. #2024
    Quote Originally Posted by aarggh View Post
    cheers,
    Ian
    Thanks mate!
    I really just needed a head spacer but why not make it a cool head spacer.
    Now I need a place to store some tools that are easy to access but I'm too lazy to pick them up myself.
    Hoss
  5. #2025
    Oct 2010
    266
    You machined the mill with itself..... I think this is how the terminator started
  6. #2026
    Quote Originally Posted by jeremy0203 View Post
    yep, that's what it's for, not gonna pay someone else to do it.
    Hoss
  7. #2027
    Jul 2011
    36
    are you using any type of feedback system, so the program knows exactly when you are vertical?
  8. #2028
    Did an experiment for the 5th axis belt cover.
    Used pretty economical PVC lumber from Lowes.
    Worked out pretty well.
    Glued a few boards together to get the thickness needed, next I'll get some 2x and 4x's to have on hand.
    Plastic boards from 100% recycled plastic. We ship USA.
    Not as dense as delrin or other plastics but it is just a dust/chip cover.
    Pretty satisfied.
    Hoss
    [ame=http://www.youtube.com/watch?v=3hn4CVcXzHw]G0704 5th Axis Belt Cover - YouTube[/ame]
    wtx, not yet.
    Attached Thumbnails Attached Thumbnails 100211 002_800x600.jpg   100211 018_800x600.jpg   100211 019_800x600.jpg   100211 027_800x600.jpg
  9. #2029
    Jun 2010
    1414
    OMFG... a rotary table to make the head rotate?!? you NEVER cease to amaze me. Its absolutely brilliant! I am dying to see that thing in action. I wouldn't know where to begin how to program the 4th and 5th axis.
    Must make tramming a breeze
  10. #2030
    Oct 2008
    1632
    Next thing you know Hoss's mill will have tracks on each side of the base so it can run around the room and pick stuff up for him. Heck, he may even send the machine to the dreaded basement on a hunt and seek mission.
    You better be careful Hoss, Hunt and seek can quickly become search and destroy!!
    Richard
  11. #2031
    Nov 2009
    4415
    Quote Originally Posted by rwskinner View Post
    Richard
    Isnt that just a big pick and place machine?
  12. #2032
    Thanks Nate!
    skinner, seems a pretty smart aleck comment but being in a wheelchair, I might have to think about it.
    Hoss
  13. #2033
    Oct 2008
    1632
    Sorry, I wasn't trying to be a smart ars. Just bragging about your machine.
    BTW, I didn't realize you were confined to a wheelchair.
    Richard
  14. #2034
    rwestbr1 commented on this video about using TREX lumber, Lowes carries it too so
    I'll have to give some of that a try as well.
    Hoss
  15. #2035
    Feb 2010
    It's been a while Hoss..I am always amazed to see how quickly your little monsters grow!
  16. #2036
    Thanks Matt! welcome back
    Hoss
  17. #2037
    I finally got around to making a video of something I've mentioned for years,
    making a single point threadmill from a tap.
    The video shows a former 1/2-13 tap cutting a 15/16-16 thread for a ballnut mount.
    After 1 spring pass the ballnut fit perfectly.
    No need to spend a bunch of money.
    Hoss
    [ame=http://www.youtube.com/watch?v=Suwl_HzouVU]G0704 Economically Threadmilling a Ballnut Mount - YouTube[/ame]
    Attached Thumbnails Attached Thumbnails 100411 022_800x600.jpg   100411 032_800x600.jpg   100411 041_800x600.jpg   100411 043_800x600.jpg
  18. #2038
    Jul 2003
    281
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Hey Hoss,
    Is there anything you can not do, Great Job:cheers::cheers:
    Bob A
    CNC Projects
  19. #2039
    Aug 2008
    962
    Great idea Hoss!
    I've been very intrigued by the idea of thread milling, but have been scared away by the cost. My wallet thanks you ..
  20. #2040
    Bob, sure, just ask my ex-wife.
    gd, I think I could make a prettier one on the lathe with a grinder and use a magnifying lens
    to see better to cut the relief with the dremel, but even this scraggly looking tool made in 15 min. did quite nicely.
    Hoss
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
